08-09-2018, 10:42 AM | #21 | |
Re: Model B Steam Engine
Looking at your picture, on the very top and between #1 and #2, it says, "THIS SIDE UP". Yet, clearly, we are looking at the head turned over. Therefore, it appears your head gasket was installed upside down. Not saying that is what caused the failure. The composite gaskets had a bad production run or something. I have had one fail that was installed properly. Sticking with stock copper gaskets on all my A's from now on. |
08-09-2018, 01:14 PM | #22 |
The main reason that I avoided the composite head gasket was because the word was that they sealed so well that they were very difficult to remove and that was withouy any sealer of any kind .
08-09-2018, 04:03 PM | #23 |
I've got the black gasket with the red silicone beading and theoretically have made the mistake of torqueing to 65 ft lbs, this under a 7:1 alloy head.
So far, 10,000 miles later and boiling a few times when I forgot to switch on the electric fan in heavy traffic, there has been no head gasket issues. |
08-12-2018, 09:38 PM | #24 |
"Snyders's has the copper B gasket. Part number B-6051-X"
and they have had it for many years |
08-13-2018, 01:36 PM | #25 |
I use the copper clad B head gasket on the engine that I run a model B head on and have had no problem in over 20 years with this gasket . The sealer is more than likely the reason that some composition B casket failed to seal for some .
08-13-2018, 04:31 PM | #26 |
https://www.snydersantiqueauto.com/b-head-gasket John |
08-13-2018, 06:33 PM | #27 |
I used the Felpro copper clad head gaskets that Larry Brumfield recommended . After all most of the head gaskets were used with his heads. Never a problem .
08-14-2018, 11:32 AM | #28 |
Not that it matters, but remember those embossed TIN gaskets, coated with a "varnish" that we used on domestics?? We just torqued them ONCE & shot them DOWN the ROAD & they RARELY failed.
There's always the question, "Did the head gasket blow & cause overheating OR did it overheat & cause the gasket to BLOW"???---ONLY the SHADOW knows, FO' SHO"--- Bill Old
08-14-2018, 12:15 PM | #29 | |
You nailed it once again, those tin gaskets didn't look like much but they sure did the job! |
08-14-2018, 05:20 PM | #30 |
I once got stuck with a Lincoln, with a re-occuring leak problem. "Someone" had coated the gaskets, with something like GORILLA-GLUE! I almost NEVER got the heads off! In the end, "someone" had overlooked a cracked L/H head!Bill W.
08-15-2018, 04:54 AM | #31 | |
