05-02-2011, 02:32 PM | #1 |
Coil id
I bought a couple of old coils at a swap meet last week. I am posting a picture of the two coils below. One has "Autolite" on it (slant pole) and the other coil has a Ford script with a oval circle around the Ford on the upper part of the coil. I am not sure if they are 6V or 12V. Does anyone know how to tell what voltage they are? There are no markings by the terminals or anywhere on the case (except what I described above) I can see. I am not sure if they are any good, but I didn't pay much for them so it is no big loss if one or both are bad. Tom W. told me how to test the coils, but I can't remember how to do it as I didn't write what he said down.
Thanks for any help with how to tell if they are 6 or 12V and if they are good or not. Rusty Nelson Last edited by wrndln; 05-02-2011 at 06:36 PM. |
05-02-2011, 05:14 PM | #2 |
Re: Coil id
First problem is that they were both more than likely oil filled coils and the oil may be gone. Shake the coil to see if they have any liquid.
Measure across the positive and negative terminals with ohm meter. meter should show fro 1 to 5 ohms, then go from one small terminal and the secondary output terminal connection--ohms should be in the 1000s like 3,000 to 12,000 ohms . If continuty is shown on both tests they are more than likely functional coils. Based on age i would guess 6 volts. The other issue would be positive or negative ground???? |
05-02-2011, 07:59 PM | #3 |
Re: Coil id
