Old 01-24-2016, 01:13 PM   #1
36 conv sedan
Default Is this a correct horn for my 1923 model T?
A friend of mine tells me my horn might not be correct... but I want to ask the experts. It does look different to what Macs has on their catalog as a Model T electric horn, but I have seen some at ebay that would seem to indicate mine may be correct... so, can anybody tell me if what I have is correct or not and if not, what model should I be looking for?
My car is a late 1922 or early 1923 touring.
Thanks!
Victor
File Type: jpg 14.12, 1922 Ford T, Touring, vmg (26).jpg (79.8 KB, 122 views)
File Type: jpg 14.10, 1922 Ford T, Touring, vmg (60).jpg (22.1 KB, 93 views)
36 conv sedan is offline   Reply With Quote
Old 01-24-2016, 02:02 PM   #2
15max
Default Re: Is this a correct horn for my 1923 model T?
No. That is a motor driven horn. A battery buzz horn with a shorter back end would probably be what was furnished. Magneto horns were also used but earlier.
15max is offline   Reply With Quote
Old 01-24-2016, 02:11 PM   #3
15max
These are the T horns. Battery left. Magneto right.
Old 01-24-2016, 11:27 PM   #4
tmodelman
tmodelman's Avatar
Correct battery horn for electric start Model 1923 Model T, a buzz horn. Makes a blat that sounds like a sad cow!
Horn body has Ford script.
Bracket mounts to head bolt and water inlet bolt.
File Type: jpg $(KGrHqR,!rgF!6n5wJSTBQQBSk4n9Q~~60_57 (640x480).jpg (167.2 KB, 44 views)
tmodelman is offline   Reply With Quote
Old 01-25-2016, 02:06 AM   #5
36 conv sedan
Thanks! Now I know what to look for!
Victor
Old 01-25-2016, 05:00 AM   #6
A bones
A bones's Avatar
My '24 always makes the geese turn their heads.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 01-25-2016, 12:11 PM   #7
redmodelt
redmodelt's Avatar
No connection;
http://www.mtfca.com/discus/messages...tml?1453709860
Old 01-25-2016, 12:13 PM   #8
36 conv sedan
Thanks for the lead, redmodelt! However my car has a battery therefore I need the electric horn. But I really appreciate your help,
Victor
Old 09-12-2017, 06:07 PM   #9
36 conv sedan
Bringing up this old subject, I found a suitable horn, just as the one Tmodelmal posted in his pics, painted it and installed it in the car. It looks great, fits great in the correct bolts, but question here is sound: it makes a nice buzz (not sure if I would call it a sad cow, as he described), but not too loud. With the engine running I guess it will not be heard by many people around... I can almost barely hear it when I am driving and I buzz it. Is this normal?
Thanks!
Victor
Old 09-12-2017, 06:43 PM   #10
28RPU
28RPU's Avatar
It looks like one that I bought which turned out to be a 12 volt horn.
Don’t pick a fight with an old man. If he is too old to fight, he’ll just kill you.
28RPU is offline   Reply With Quote
Old 09-12-2017, 10:03 PM   #11
longhaul
Curious to know how it sounded....
longhaul is offline   Reply With Quote
Old 09-14-2017, 08:49 PM   #12
piewagon
I make reproduction Battery Horns for 1922-1927 Model T. The magneto horn started to appear on a few of the 1915 Model T but then was around for the entire production run through 1927 since the electric car with starter was an optional package. The electric car started in 1919 but the battery horn was not introduced until about March of 1922. Battery horn if adjusted properly should draw 5 amps DC and be fairly loud. The gap between the end of the plunger and the diaphragm should be set to 1/32" which is easy to set.. You just loosen the plunger lock nut and screw the plunger IN until a lite tap on the end of the plunger no longer delivers a "click" heard when it hits the diaphragm. Continue to screw the plunger IN to make it closer and eventually the click will go away because the plunger is touching it. Don't force this - you want the plunger to just barely contact the diaphragm and then back the plunger out 1 full turn since the thread on its plunger is a 10-32 thread and one turn = 1/32" advance or withdraw of the plunger. Once you have that spot then lock the locknut. Now fiddle with the point gap until you get 5 amps using 6V battery that is fully charged. Failure to achieve much sound or dim amounts can be a faulty horn winding or bad points but most often is because the diaphragm is full of rusted holes. I make new diaphragms out of stainless steel and use those on my horns but since all mechanical parts are made to factory drawings my diaphragm will fit your horn. Good luck with it
http://www.funprojects.com/products/6432.aspx
piewagon is offline   Reply With Quote
Old 09-16-2017, 01:02 PM   #13
41panelmark
41panelmark's Avatar
So what does the horn look like and where does it mount for a Magneto car 1918? I have a Battery horn on mine and would like to change it out for a Magneto one.
thanks.
41panelmark is offline   Reply With Quote
Old 09-16-2017, 01:02 PM   #14
41panelmark
thanks.
Old 09-18-2017, 12:05 AM   #15
longhaul
Thanks!
Victor
By the way is that your car Victor? Looks very neat and clean.
Old 09-22-2017, 06:46 PM   #16
36 conv sedan
Hey, Piewagon!
This is the best explanation I could have ever hoped for! Sorry I thanked you till now but I hadn't been able to get into the forum.
I will print and try the procedure this weekend... and if I my diaphragm needs replacement, I will sure contact you. Your page shows you make fantastic products, congratulations!
victor
Old 09-22-2017, 06:52 PM   #17
36 conv sedan
Yes, that is my car. It looks decent but it is not fully correct. It has a much nicer top that what they originally used (I got it this way already) and uphostery is a bit off also... pleats are too pronounced. Background is an acueduct we have here in Queretaro, Mexico. Here is the car with an antique factory now turned into a school...
And two additional shots of the engine compartment with the horn in place.
Old 10-09-2017, 08:10 AM   #18
Royce P
Royce P's Avatar
Mark, the Magneto horn mounts as shown in this photo in 1917 - 18 on the firewall.
thanks.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 10-14-2017, 11:35 AM   #19
41panelmark
Royce, I have a battery horn that mounts like that and today I picked up a Mag horn that looks like the 2nd photo. That horn has Ford script on it and only one terminal. If not for 17/18 what year do you think it was for?
Old 10-14-2017, 04:28 PM   #20
Royce P
Royce P's Avatar
The ones that mount on the firewall need two terminals since the wooden firewalls don't offer a ground. I don't know what year they started mounting MAG horns to the engine but that horn must be intended to mount to the engine. I am guessing 1922 or later.
That horn will work on a 1917 of course, you just need to add a ground wire someplace.
1910 Touring
1914 Touring
1915 Touring
