Old 03-12-2015, 03:36 PM   #1
mike37cdn
Default setting valves on a 1936 221 v8
I am putting new valves in my 36 the new ones are stainless replacement ones what is the best setting for these the book says 10 to 12 intake and 14 to 16 on the exhaust thanks mike
mike37cdn is offline   Reply With Quote
Old 03-12-2015, 04:26 PM   #2
mike37cdn
Default Re: setting valves on a 1936 221 v8
no ansewer
Old 03-12-2015, 04:48 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Give all the old, smart guys a chance to finish their siestas. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-12-2015, 05:15 PM   #4
flatjack9
flatjack9's Avatar
I run 12 on the intake, 14 on the exhaust. And don't be so impatient. I just got home from work. We all don't sit around on the computer all day.
Old 03-12-2015, 07:17 PM   #5
mike37cdn
ok sorry I am real close to getting it together 6 years now on the road soon I hope
Old 03-14-2015, 07:29 AM   #6
mike37cdn
anyone have more
Old 03-14-2015, 07:59 AM   #7
wamnram
wamnram's Avatar
Mike, you probably won't get any more answers because you already have the correct one. Set the lash as stated. Too much lash and tickety-tick. not enough and burned valves.
Wayne
wamnram is offline   Reply With Quote
Old 03-14-2015, 08:00 AM   #8
38 coupe
38 coupe's Avatar
Your clearances depend on the cam you are using. flatjack9 gave you the correct clearances for most stock cams. What cam is in your motor?
Old 03-14-2015, 12:43 PM   #9
Russ/40
Russ/40's Avatar
Yup, 12 and 14 are the way to go.
Russ/40 is offline   Reply With Quote
Old 03-14-2015, 02:42 PM   #10
Brendan
Brendan's Avatar
I use a stepped type feeler gauge
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 03-14-2015, 05:14 PM   #11
FlatheadTed
FlatheadTed's Avatar
If you are using adjustables then the 12 & 14 wont do -tap -tapedy , tap .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-14-2015, 05:38 PM   #12
mike37cdn
stock cam thanks you
Old 03-14-2015, 07:04 PM   #13
flatjack9
flatjack9's Avatar
What?
