Old 09-23-2013, 04:44 PM   #1
mike37cdn
Default 49 merc shitfers on the trans
just picked up a 49 merc with 34000 original miles but it been rode hard and put away wet the shift arms are badly worn does a shifter from a 51 merc fit the 49 trans thanks mike
mike37cdn is offline   Reply With Quote
Old 09-23-2013, 06:24 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 49 merc shitfers on the trans
It depends on if you are wondering about steering columns, shift rods, or transmission mounted shift levers. The early 51 is the same in the shift lever department but the late 51 has different levers. There are differences in the early 49 columns and the later 50/51 columns. I've installed the shifter arm bushing kits and re-riveted the levers on on several Merc transmissions. It's a job but the hardest part about it is adapting the replacement parts to work correctly. They use solid brass inner bushings instead of formed brass sheet material and it makes them hard to peen the centers to hold the assemblies together. The shift rods can be straightened and built up with brazing if they get screwy & worn. Mac VanPelt sells some clevis pins that work well to re-rivet the levers back on the transmission cover.
