03-17-2017, 08:00 AM | #1 |
Greasing front wheel bearings, thanks!
After searching and reading through all the threads for information and confidence I tackled a job I had never done before last night. Took about 15 minutes a side and left me with a big grin.
I bought the wheel bearing grease from NAPA after a couple threads mentioned guys using it. I watched a video on YouTube about how to do it. And I read Les Andrews instructions on how to do it. I used Sta-Lube Wheel Bearing Grease NAPA # SL3111, for reference. Just wanted to say thanks to everyone that contributes to the board so that new young guys like myself can access your knowledge. I'll be redoing the rears eventually, but this was a quick and easy preventative maintenance.
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
03-17-2017, 10:30 AM | #2 |
Re: Greasing front wheel bearings, thanks!
Way to go! Doing the job your self is very satisfying. The rears are harder only because you'll probably need a puller to get the hub off.
03-17-2017, 10:35 AM | #3 |
Yes, nice work!
The neat thing about a Model A is you can do most anything with simple hand tools and maybe a couple specialty tools.... Plenty of expert help available here! Now I have a question. The roller track that supports the bottom of your brake shoes....is that stock? I ask because they are different than mine, and I'm wondering if maybe I'm missing a part.... But, it might just be the difference between your 31 and my 29 brakes...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
03-17-2017, 11:06 AM | #4 | |
03-17-2017, 12:24 PM | #5 |
I have no idea guys. This is my first A and the first time I did the job. It was suggested on Facebook that they might be B's?
03-17-2017, 04:06 PM | #6 |
03-17-2017, 04:19 PM | #7 |
Whatever they are it looks like a better system...the normal A only has one roller track between the shoes and the backing plate...
It's neat to be able to learn from others posts and pictures!
03-17-2017, 04:21 PM | #8 |
Some floater arrangement maybe?
03-17-2017, 08:12 PM | #9 |
Maybe an add-on to help deal with worn-out roller tracks?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
03-17-2017, 08:25 PM | #10 |
03-17-2017, 09:37 PM | #11 |
I hope you pre-loaded the bearings with 5 Ft Lbs of torque!
Bill W.
03-18-2017, 07:05 AM | #12 |
03-18-2017, 07:14 AM | #13 | |
I NEVER recommend ANYTHING that has not worked for me in the past! Trust me on this! I've been doing this ALL my working life. Bill W.
03-18-2017, 09:16 AM | #14 | |
Not sure about that as it may have been one of those aftermarket fixes.. maybe the rear track was worn so they supplied that to fix it. Which seems to me then the shoes would could be cocked. Hopefully the cotter pins are in the clear. Not much room on some pins. I think I'll stick with the "Henry" stock tracks. One thing that is an excellent example is the one showing the drum on with the grease can above. It shows exactly where a stock wheel contacts the drum in 3 places. Excellent photo! BTW.. your age? We are so glad you found the "A" and the forum! I started in our club just out of high school.... couldn't imagine not having done this! "A" folks are the best! Larry Last edited by larrys40; 03-18-2017 at 09:24 AM. |
03-18-2017, 09:26 AM | #15 | |
Also check the bearing cup..the part that is pressed into the hub...make sure it too is smooth without cupping or pitting. I think Bill means that you should tighten the nut to 5 pounds of torque when you re-assemble. You should start a thread with pictures when you start the project so others can help when judging the bearings condition........there is more to it than what I mentioned
03-20-2017, 01:35 PM | #16 |
1955cj5,
Thanks, I will try to take pictures. I pulled both hubs off already and gave them a quick clean and fresh paint. I'll post some pics when I get back out there. I was hoping it would have warmed up a little more by now. I was confused by the 5 pounds of torque. I hadn't read that anywhere. The Les Andrews book says to tighten it and then back it off a bit. |
03-20-2017, 02:44 PM | #17 |
Tighten while turning the wheel and back off till it turns freely to the first slot that allows the cotter. Tightening seats the bearing.
03-20-2017, 03:21 PM | #18 |
Here is a link to a YouTube video by Timken on how to adjust the wheel bearings.
https://www.youtube.com/watch?v=0RqlrnoiqnY Bob |
03-20-2017, 03:58 PM | #19 |
Here is the video that I watched.
This plus the Les Andrews book got me through it. https://youtu.be/sO9By03k4wo
03-20-2017, 08:41 PM | #20 |
Here are some pictures of mine. Yes, that is some sort of creature in the upper left.
