10-19-2011, 09:07 AM | #1 |
running boards 41 ford
im trying to remove my running boards to install new covers but the bolts holding the running boards are rusted and just turning is there any access to these nuts that im not aware of. any help appreciated
10-19-2011, 09:26 AM | #2 |
Re: running boards 41 ford
You can use a hole saw to cut a hole in the top side of the rocker box to try to get to the cage nuts. If you do that you can then patch the holes you cut which will be covered by the floor mat.
Dick |
10-19-2011, 11:32 AM | #3 |
I would thing you would prefer to cut the head off the bolt before cutting holes in the rocker.
Once the boards are removed you would need to either find a way to weld or hold the nut from the bottom side and remove the leftover bolt. Option two is to punch the bolts in and replace with new. Back to your original question " is there any access to these nuts that im not aware of" Not from the factory. Dave W |
10-19-2011, 02:06 PM | #4 |
These bolts go into cage nuts , if you cut or punch them out, just how do you recomend holding the new bolts on. Have you ever seen a rocker box?
10-19-2011, 06:28 PM | #5 |
Replaced both sides on my car.
You can weld a nut into the hole if you punch them out or you may be able to install new cage nuts. |
10-19-2011, 08:35 PM | #6 |
On the B-pillar I just used windows and for a 5/16 U-nut widely available from Mustang vendors |
10-19-2011, 10:53 PM | #7 |
It will work from the top or bottom just as well. The bottom is covered by the running board and the top by the floor mat. I just found it easier to work on the top than the bottom. The thing about using cage nuts instead of welding a nut to a hole is when you are installing the running board the cage nuts will allow a little movement to align better
10-25-2011, 12:29 AM | #8 | |
11-11-2011, 03:34 PM | #9 |
Hi,
as i remember the "l" shaped brackets that hold the running board to the frame are secured with bolts and nuts. Rather than trying to remove the board from the bracket, it might be easier to work on it if the bard is removed trom the car itself. You might consider using all stailless steen hardware. No rust remember, "rustless" stainless steel will not attach itself to a small magnet. Some so called "stainless" steel has too much steel in it . I hope this helps. Big al |
