Old 11-20-2012, 07:09 PM   #1
cooke
cooke's Avatar
Default LED turn signals
I just bought a 31 coupe that the owner installed new rear LED running and brake lights but no turn signals. What is the best way to convert these to work as turn signals also. Wiring is really not my background. Thanks
cooke is offline   Reply With Quote
Old 11-20-2012, 09:43 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: LED turn signals
I would run seperate turn signals and leave the original wiring and lights alone. It'll make installation and any future trouble shooting much easier.
Old 11-21-2012, 12:02 AM   #3
ba49
I have Logo Lights turn signals on my Sedan and they are great. Very bright and only one wire to each light. they fit between the bumpers. They also work as emergency lights.
ba49 is offline   Reply With Quote
Old 11-21-2012, 12:46 AM   #4
1936ford64
Making the directionals work is fairly simple. The switch is a convenience and the flasher unit is the interupter of the brake light.
1936ford64 is offline   Reply With Quote
Old 11-21-2012, 05:25 AM   #5
dr.j
I also installed Logolites in my 28 Tudor in addition to a rear window brake light bar. Very pleased with the product and especially the 4 way flasher option.
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 11-21-2012, 07:26 AM   #6
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
For someone not electrically inclined, I would also suggest the Logo-Lite system. It is so easy that even I can do it------and I am the worst person in this forum to have as a helper in all matters of an electrical nature. Just make sure you have a few spare one amp fuses on hand. Never substitute with any higher amperage because you WILL fry the "brain box," eventually.
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 11-21-2012, 10:27 AM   #7
John LaVoy
John LaVoy's Avatar
We have used various systems to do turn signals. Bratton's sells a complete wiring harness with the turnsignal system built in. This makes a very clean installation and simple to do because you just run the wires like original.
John LaVoy is offline   Reply With Quote
Old 11-21-2012, 11:10 AM   #8
CarlG
CarlG's Avatar
I have the Signal-Stat 900 unit that I got from Sacramento Vintage. They wire this especially for the Model A and it can use cowl / Stop lights or you can provide separate lights.
Old 11-21-2012, 11:23 AM   #9
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Turnswitch.com.....that is all you need to know!
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 11-21-2012, 01:30 PM   #10
TudooR31
TudooR31's Avatar
I went with LogoLites, too. Ran the wires through 'Black Bulk Fabric Loom' from Snyders (you will need 27 feet) and used black steel wire to attach to bumper brackets, steering column so it would look sort of period correct. The right front wire went across radiator base in clips for headlight. The right rear wire uses frame clips on rear cross member by rear spring. The controller box magnet mounts almost hidden on the gas tank up under the dash. You can still reach it easily. Has 2 buttons that blink when pushed. Makes a little cricket chirp while blinking. Push both buttons for 4-way flashers. You can see them on my avatar.
TudooR31 is offline   Reply With Quote
Old 11-21-2012, 03:53 PM   #11
Mitch Bunkin in PA
Mitch Bunkin in PA's Avatar
I've had Logolites for 3 or 4 years & love them. I attached wires to frame using those black plastic "slip through" ties you can get at hardware store.
My grandchildren love to hear the chirping, cricket sound when I make a turn!!!
WEBSITE=http://faculty.bucks.edu/bunkinm/
"Most people ONLY want to know
what they already believe and
nothing more."
Mitch Bunkin in PA is offline   Reply With Quote
