Go Back   The Ford Barn > The Swap Meet > Wanted > Model-T
Old 12-27-2012, 02:27 PM   #1
southfork
southfork's Avatar
Default TT Dash Panel with Support for Steering Column
City: Rigby
State: Idaho
I seem to have lost the cleaned and primed dash panel that came with my 1926 TT steel Cab truck. I'll probably find its sometime, but I wish to work on and fully assemble the cab this winter. Anybody have a TT dash with steering support for a '26 Truck cab? Also, would the dash ignition switch plate for a '26 TT be the rectanglular painted type or the the rounder nickel type? I can't remember. The dash would have to be the right one for a 1926, in case the hole for the switch plate changed between years.
southfork is offline   Reply With Quote
Old 12-27-2012, 05:07 PM   #2
Farmallcub49
Farmallcub49's Avatar
Default Re: TT Dash Panel with Support for Steering Column
The Ignition switch should be the rectangular type. I may have a dash, but I'll have to check.
'OSO HANDY RESTORATIONS
Specializing in Model T Fords
320-293-1953
Farmallcub49 is offline   Reply With Quote
