Old 05-02-2013, 03:59 PM   #1
Tugmaster
Default Burnt engne paint. Potential problem??
Here are some pics of the burnt paint on the engine my Model A. A little back ground first. The entire chassis and drivetrain were rebuilt about 8 years ago. The owner put the body on the chassis and was getting ready to take it to the bodyshop and he passed away. The car sat in his widows basemet till about a year ago. The guy I bought it from brought it home. put a battery in an it fired ight up and idled fine. This still has breakin oil in it.
My question/concern is why did the paint burn off? Was the motor "tight" after the rebuilt and get to hot. Carb to lean?Or maybe just lousy paint!
The water pump is working and I asume the oil pump too
Any thoughts or steps I should take to make sure there are no issures or potential problems down the road?
Thanks,
Todd
Tugmaster is offline   Reply With Quote
Old 05-02-2013, 04:06 PM   #2
gwhite
gwhite's Avatar
Default Re: Burnt engne paint. Potential problem??
Todd,
That damage to the paint doesn't appear to be from burning per-se. I see that condition behind the water outlet - a place that should be much cooler than the head alongside the manifold. I'd say what you're dealing with is poor prep prior to finish painting more than anything. The fact that the head studs/nuts are painted seems to indicate that paint was probably slapped on without much thought. Strip off what you can (down to bare iron) with a wire brush/stripping wheel/solvent - thoroughly degrease, and paint it with a quality paint. I've used cheapo implement enamel on engines and never had an issue - provided I prepped it well.
gwhite is offline   Reply With Quote
Old 05-02-2013, 04:23 PM   #3
Richard Wilson
Richard Wilson's Avatar
I agree. The paint is peeling off due to poor adhesision and NOT burning off. It appears that there was very little cleaning or prep before brushing on the engine green paint.
Richard Wilson is offline   Reply With Quote
Old 05-02-2013, 04:27 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Below is some pictures of an engine damaged by excess heat. Yours ain't nothing similar from what I am seeing!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-02-2013, 05:00 PM   #5
700rpm
700rpm's Avatar
Brent, do you know what caused that excessive heat?
Ray Horton, Portland, OR
Old 05-02-2013, 05:02 PM   #6
H. L. Chauvin
Humble Opinion:
It went like this:
"Give your old engine & we will swap it out for a re-built one with a "fresh coat of paint".
Every Model A engine I cleaned that was rebuilt several times years ago went like this:
1. Apply paint remover & remove paint.
2. Then find a unique mix of grease & dirt which had to be cleaned.
3. Next repeat steps 1. & 2. several times going through different layers with several coats of paint.
4. Finally one discovers flakes of rust & sometimes slightly pitted metal
Your vintage found engine looks so normal to me, it is like looking at a morning cup of coffee.
The guys with the paint brushes could have been hoboes & drifters before the welfare programs -- this was so normal throughout the 1940's -- most State Sign Shops hired hoboes to paint traffic signs on plywood until the silk screen process got popular along with Civil Service & Government employees.
Paint over grease was cheap & quick & looked good until the grease got warm at engine running temperature.
I remember hoboes sharing & eating a cans of dog food.
H. L. Chauvin is offline   Reply With Quote
Old 05-02-2013, 05:46 PM   #7
BRENT in 10-uh-C
Yes.
BRENT in 10-uh-C
Old 05-02-2013, 07:33 PM   #8
1crosscut
1crosscut's Avatar
Originally Posted by BRENT in 10-uh-C View Post
Yes.
Nice
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-02-2013, 09:06 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
T.S.P. (tri sodium phosphate) is a great cleaner & it etches existing paint slightly for better paint adhesion! It removes grease, wax, oily residue, etc. Mixed thick like pancake batter, it will strip paint, not fast, but very safe! I mix it in warm water to soak carbs & I've used it to clean greasy/oily residue from cooling systems & it DOESN'T foam. Available everywhere. Bill W. (NO! it doesn't help for the toilet, only the PUMICE stone works!)
"THE ASSISTANT GURU OF STUFF"
Old 05-02-2013, 09:29 PM   #10
Peter J
Peter J's Avatar
It sure looks like an engine fire starting at the carb. The manifold area protected the paint directly above the carb from blistering but it creeped around both ends. Looks like some gas pooled on top of the cam cover.
Peter J is offline   Reply With Quote
Old 05-02-2013, 11:23 PM   #11
tbirdtbird
Looks like it was run hard retarded to me...
nice pix, Brent....
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-04-2013, 04:57 AM   #12
BRENT in 10-uh-C
Originally Posted by tbirdtbird View Post
looks like it was run hard retarded to me...
Nice pix, brent....
BRENT in 10-uh-C
Old 05-04-2013, 09:11 AM   #13
H. L. Chauvin
Hi Brent,
Good point!
FWIW:
We use the term "retarded" quite often "only" in refering to our Model A distributor timing.
I think after seeing us working on our Model A's until late at night, some of our modern day neighbors think about us & the meaning of "retarded" in a more general sense. LOL
Old 05-04-2013, 10:41 AM   #14
BRENT in 10-uh-C
Originally Posted by H. L. Chauvin View Post
Hi Brent,
Good point!
FWIW:
I guess I was being vague above as to slightly protect the guilty.
FWIW, the term "retarded" is used in the Model A Instruction Book (owners manual) to describe the spark lever position, so I am sure that is why many folks still use that term today.
I do not know for a fact (...and likely never will!! ) that the spark lever was retarded when all that happened however the driver complained the vehicle was really underpowered and felt like it was really laboring. Instead of pulling over to ask questions, they proceeded until it blew all the water out. It even split the lower tank on the Brassworks radiator. They sent me a video of it ...and the steam blowing out the bottom would have made an old steam Train Engineer proud!! I offered to fix it under warranty for the customer since it only had a couple hundred miles but in retrospect, I think "guilt" got the best of him as he chose to use another vendor to rebuild the engine. It had less power afterwards since that vendor advised him to go with a 5.5 head instead of a 6:1. THAT seemed 'retarded' to me!!
BRENT in 10-uh-C
