02-26-2015, 10:39 PM | #1 |
Speed Head
I have a head that came on the bed of an AA I have. Only marking is 'speed head'. Looks to be in good condition. Is this early speed stuff that is desirable? I installed it with an unused but well handled head gasket the seller gave me, went out on a test drive, blew the gasket and my wife had to tow me home..... I am trying to sell some surplus stuff to fund my '47 tonner panel project. No idea how to price it in classifieds.
02-26-2015, 11:14 PM | #2 |
Re: Speed Head
Do you have any pictures of the head?? If you post them here, people will be able to give you a better idea of what it is worth.
02-27-2015, 12:03 AM | #3 |
Re: Speed Head
I will get some in the morning. Thanks! Here's my AA which has a stock head now (and a high tec kevlar gasket from Olsen's)
02-27-2015, 12:19 AM | #4 |
Re: Speed Head
I had one as you described and it worked well and ran good.
02-27-2015, 08:18 AM | #5 |
Re: Speed Head
Kool picture. Whatcha cooking??? ken
02-27-2015, 08:54 AM | #6 |
Re: Speed Head
02-27-2015, 11:40 AM | #7 |
Re: Speed Head
Vince has some information on his site about that head.
http://www.fordgarage.com/pages/head...ssionratio.htm Bob |
02-27-2015, 03:03 PM | #8 |
Re: Speed Head
A whole pig! I'll get pics of head after lunch. Cyl head, not the pig's......
03-01-2015, 12:37 PM | #9 |
Re: Speed Head
Pics of the speed head.
03-01-2015, 07:31 PM | #10 | |
Re: Speed Head
I don't know how many mod. A heads you've replaced, but it looks easy but it can be a big deal. First thing, did you check it for flatness? Next, Some don't, but I like permatex on both sides of the gasket. Then there's the torqueing and retorqueing sequence. Altogether, it gets torqued about 4-5 times. since I started doing it this way, I haven't had a leak or a blown gasket. BTW It sounds and looks like you were over heating. This is a good time to clean out and flush the block and radiator.
Terry Quote:
03-01-2015, 09:59 PM | #11 |
Re: Speed Head
It was just the head that was sitting on the script stakebed when I bought the AA last year. There was no head on the engine at the time. I made sure it was clean, took the gasket he gave me and bolted it up, using a torque pattern that made sense from years of shade tree mechanicing. After it blew, I did some research about torqueing on fordbarn and got a different stock head and new gasket. Yes it overheats because the radiator is clogged, but the white smoke is from a wood fire in the pig roaster on back. I have it on the back burner waiting for a radiator. Maybe someone wants the speed head for a rad???
