08-01-2014, 09:55 PM | #1 |
fuel regulator
I have a 47 ford pickup with a flathead V8. I installed a carter electric fuel pump. Do I need a fuel regulator to reduce the pressure from 6 psi. It seems to run fine with no regulator. I live at 10,000 ft if that makes any difference. Jim
08-15-2014, 11:50 AM | #2 |
Re: fuel regulator
You should post your questions in "General Discussion" in the Early V/8 section. good luck,,, .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
