Old 04-11-2019, 01:04 PM   #1
elwood
elwood's Avatar
Default Identifying Lincoln brakes ,
Hey guys, I have a Lincoln Front and Rear axle, and Im needing to find brake parts for them, so Im thinking I need to know the approximate year, and if anyone knows a good place to find parts Id appreciate it ..
Thanks …..
elwood is offline   Reply With Quote
Old 04-11-2019, 02:01 PM   #2
Fordors
Default Re: Identifying Lincoln brakes ,
I can't be sure from your photos, is that backing plate offset about 3/4" deep? If so they are '42-'48 Lincoln and will fit '37-'48 spindles. If deeper than that then the mounting holes should be 3/8" and they will be a direct bolt on to the early '32-'36 spindles, and just to confuse things there was also a flatter recess backing plate from the 1941 Lincoln.
Also keep in mind that Lincoln king pins are a larger diameter and have a different KPI, so even if you sleeved them for Ford k/p bushings you have to bend the axle for correct camber.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 04-11-2019, 03:23 PM   #3
russcc
I believe the question was, can we help ID the years of the brakes on the Lincoln axles shown in the photo so he can locate parts for the brakes. "Fordors" is correct, the deep set backing plates are likely '42-48, as the earlier ones were similar to the Ford setback, and why they are the preferred brake for conversion to Ford axles & spindles.
russcc is offline   Reply With Quote
Old 04-11-2019, 03:39 PM   #4
Jason in TX
Jason in TX's Avatar
A little pic I put together.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 04-11-2019, 04:16 PM   #5
Fordors
Thanks to Jason, somehow I omitted the years when I described the deepest backing plates.
Old 04-12-2019, 04:01 PM   #6
elwood
elwood's Avatar
42 to 48, thanks Jason
