04-22-2011, 05:52 PM | #81 |
Re: 1930 Ford Sheetmetal Work
started on all the stuff today
bobs hood some extra holes for some reason other side holes doms fenders i didnt like the patch that was in there so i put a new one in about 3 more inches to go stay tuned for more progress!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 09-15-2011 at 07:35 AM. |
04-22-2011, 06:25 PM | #82 |
It might be his car. And he might be able to fix whatever happens to it if something does.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
04-22-2011, 06:31 PM | #83 |
thats my car. calm down. i would never do that to a customers car.
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom |
04-23-2011, 12:09 AM | #84 |
Oh!! that's the good taste of something made by yourself, That´s have another value!!
04-23-2011, 12:49 AM | #85 |
You have a lot of talent for a 25 year old. I keep looking at all the pictures over and over hoping some of your talent will rub off on to me.:-) Love the work. thanks for posting
04-23-2011, 08:50 AM | #86 |
04-24-2011, 12:01 PM | #87 |
thanks everyone glad yu guys are enjoying the work if ya have any questions feel free to ask
finished up the first set of fenders can figure out why these holes were here small patch a small tear where the fender support goes took out the reinforcement thing by drilling 2 spot welds. cleaned up the rust and hit it with weld thru primer a tear on the edge of the fender a new reinforcement bracket for the fender where it meets the running board again both hit with weld thru primer one more full set to go!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 09-15-2011 at 07:37 AM. |
05-04-2011, 08:02 AM | #88 |
broken motor mount. guess 80 or so yeras of service took its toll.
these fenders looked killer until i went to start on filling the old taillight holes ohhhh its so nice of you to plastic up both sides of the fender to hide some mess a little hammer and dolly work to get thing baack to normal before cutting out the area with the holes.
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 10-01-2011 at 07:30 AM. |
05-04-2011, 01:05 PM | #89 |
Very nice welded seam
05-04-2011, 02:13 PM | #90 |
You are doing nice work.
I have a couple of suggestions based on my experience. You really want to do all the front and rear fender repairs on the frame with the brackets set up. You can lock in deformities that will make fender installation almost impossible. I had to undo some beautiful bodywork on a pair of fenders I bought. They were done off the frame and would not fit at all!!! It appears you were putting in a flat piece of metal at the tail of the fender. The 30-31 fenders are a compound curve in that area. The metal should be formed first before welding in place. From looking at your welding, do not try a TIG welder unless you can afford to buy one. You are not far from putting in panels with little or no grinding- just some hammer on dolly planishing. You are likely to find a TIG welder to be a wonderful change. |
05-04-2011, 03:40 PM | #91 |
Flop,
Nice work! What size tungsten an filler rod are you using? The front fender, plus other parts look hot/too much rod, for an easy clean-up. Dudley |
05-04-2011, 03:58 PM | #92 |
very inspiring you keep tackling the hard stuff and come up looking good! what is weld thru primer and where do you get it?
Rust and roll will never die |
05-04-2011, 05:52 PM | #93 |
Fixing the rear motor mounts, now you're just showing off.
05-04-2011, 08:58 PM | #94 |
thanks guys.
dj the tungsten is 3/32nds filler is prob. double the size of a .023 piece of mig wire. i use alot of rod for sure. i like to make sure i get it over lapping the seam to act as a filler i dont know why just have the best results that way.as far i heat i am set on 70 amps and have never been into the pedal id say more then half way. thanks kevin . the front fender with the tear on the edge was was tacked in place on the car and the matched to a perfect unaltered a fender and both had the same curve in the front . rolling... weld thru primer is a primer you can weld through.i put it in areas like behind brackets that get spot welded etc. thanks mike
05-04-2011, 09:57 PM | #95 |
VERY NICE WORK!!!!
Where were you when I was doing the sheetmetal on my car???? Chris |
05-07-2011, 05:56 AM | #96 |
i would have to kno the date you were doing your sheetmetal chris!
finished up the rear fenders with the bad holes. i guess these were on a roadster because he said the whole in the top of the passenger side was for a step. other fender 4 really reaaly bad condition front fenders with spare tires holes next and a set of splash pans.
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 05-07-2011 at 04:37 PM. |
05-07-2011, 11:34 AM | #97 | |
Your posts are probably one of the most interesting there are on FordBarn !! Keep up the good work, and keep posting !! |
05-07-2011, 11:56 AM | #98 |
I agree. They say a picture is worth a thousand words but along with your commentary to help understand what we are seeing is an added bonus!
05-07-2011, 12:10 PM | #99 |
Hi Gent's are there any stronger words then only " perfect job"... this guy is top.
Flop may thanks sharing this with us. Gerard |
05-07-2011, 01:23 PM | #100 |
Don't you dare stop!!!
