Old 05-28-2016, 02:58 AM   #1
Lawrie
Lawrie's Avatar
Default cam shaft centre line
Any one know the centre distance between the camshaft and the crankshaft centres.
also the bore diameter of the block were the valve guides fit.
Thanks Lawrie
Lawrie is offline   Reply With Quote
Old 05-28-2016, 03:31 AM   #2
34 FORDOR
34 FORDOR's Avatar
Default Re: cam shaft centre line
Lawrie Have a look on Vince Falters site , ford garage.com. I know he has the center line measurements you need . Good luck
34 FORDOR is offline   Reply With Quote
Old 05-28-2016, 05:02 AM   #3
colin1928
colin1928's Avatar
Lawrie I set up for 4.155"
colin1928 is offline   Reply With Quote
Old 05-28-2016, 05:29 AM   #4
Lawrie
Lawrie's Avatar
Thanks Guys that is exactly what I needed.
Lawrie
Old 05-28-2016, 07:02 PM   #5
Lawrie
Lawrie's Avatar
Thanks ,Measured the centres this morning,.008 under,
Lawrie
Old 05-29-2016, 11:58 AM   #6
jpcouture
jpcouture's Avatar
My crank and cam were about .004 too close. I figured it out after chewing up a few fiber gears. Dan McEachern (510) 532-8228 (California) made me a beautiful custom gear set to resolve my problem. Dan is very knowledgeable and reasonable price also.
jpcouture is offline   Reply With Quote
Old 05-29-2016, 03:01 PM   #7
Dodge
Dan did the same for me they mesh perfectly. Thanks Dan...
Dodge is offline   Reply With Quote
Old 05-30-2016, 10:19 AM   #8
Fred A
Fred A's Avatar
Four and a half years after this thread, I had to call on Dan to provide me with a -.005" timing gear to salvage a "fresh" short block that has been haunting me for decades after a run-in with America's Sweetheart antique engine family. The mains had been line bored just a little off. Hoping that it's not your problem just keep the Dan option in mind if it continues to destroy timing gears. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 05-30-2016, 03:50 PM   #9
Lawrie
Lawrie's Avatar
Sure will, I have just yesterday fixed the main bolts looseness up,and will then look at the fix for the cam.
Lawrie
Old 05-30-2016, 04:36 PM   #10
colin1928
colin1928's Avatar
Lawrie I am sure you know but check center line front and back
Old 05-30-2016, 04:41 PM   #11
Lawrie
Lawrie's Avatar
Sure will
Lawrie
Old 06-11-2016, 12:58 AM   #12
Lawrie
Lawrie's Avatar
Would any one have an e/mail for Dan Mc eachern.
to save me ringing at an ungodly hour for me.
Thanks Lawrie
Old 06-11-2016, 03:47 AM   #13
colin1928
colin1928's Avatar
Lawrie try
[email protected]
Old 06-11-2016, 04:53 PM   #14
Lawrie
Lawrie's Avatar
Thanks Colin,
I,m onto it.
Lawrie
