Old 05-27-2016, 06:48 PM   #1
klrh20frank
Default wheel repair
has anyone had any luck repairing model a wheels that have small cracks eminating from the spoke holes. can they be stop drilled and welded?
klrh20frank is offline   Reply With Quote
Old 05-27-2016, 09:02 PM   #2
J Franklin
J Franklin's Avatar
Default Re: wheel repair
Model A wheel spokes are welded (no holes), so I don't know what you are referring to.
Old 05-27-2016, 09:24 PM   #3
ian Simpson
Check out http://www.durableperformance.net/Do...2.4.09.web.pdf
ian Simpson is offline   Reply With Quote
Old 05-27-2016, 09:33 PM   #4
1955cj5
1955cj5's Avatar
I welded the hub of one of my wheels about a year and 1000 miles ago....seems OK...I welded it on the inside....at the same time I also welded one of the spokes back onto the rim......if you weld on the rim,take the tire and tube off!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-27-2016, 09:38 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I've drilled a hole where the spoke broke loose from the hub or rim, then welded the spoke from the backside. This will leave the spoke attachment neat as original, and when the weld cools it will pull the spoke tight.
Old 05-27-2016, 11:44 PM   #6
Dodge
Thanks for the info Tom
Dodge is offline   Reply With Quote
