05-28-2016, 10:24 AM | #1 |
Axel key
Question...Which way does the axel key go in this is a 30 Phaeton. I don't want to pull the drum again, it was a real bear getting off.
05-28-2016, 10:44 AM | #2 |
Re: Axel key
All axle keys that I've seen have the tapers both facing the same way, and are installed with the taper towards (against) the axle. The longer, straight, side against to hub.
05-28-2016, 10:57 AM | #3 |
Re: Axel key
No 2 in photo, inboard and down. The key way in the axle has a curve that the taper fits into. Most keys I have seen just have the one taper, No 2.
05-28-2016, 11:07 AM | #4 |
Re: Axel key
Thanks Guys......don't know what I'd do without the barn.
05-28-2016, 12:58 PM | #5 |
Re: Axel key
A follow up on that axel key I have pictured is a new key never used straight from the vendor. It doesn't fit in the hub slot. If you use new keys check them out. Don't do what I did assume there perfect.
05-29-2016, 07:41 AM | #6 |
Re: Axel key
05-29-2016, 12:56 PM | #7 |
Re: Axel key
Here's an old thread that discussed the orientation of the rear axle key; perhaps it will be helpful:
http://www.fordbarn.com/forum/showthread.php?t=136160 |
05-29-2016, 08:47 PM | #8 |
Re: Axel key
taper goes out and up
