05-27-2016, 09:26 PM | #1 |
1931 Model A not starting
OK, Here is the story I Have a 1931 model A the car was sitting for about 2 years. I cleaned the gas tank all lines to the carburetor. Added new filters, had cab rebuilt. added new gas. The distributor was rebuilt with modern points. Also got new coil and wire, new plugs. Had car running on the first start. Ran real good. ran for about 2 weeks no problems. then I thought to reset timing. because it was running a little rough. Then no start. I also checked the gaps on points and plugs .Checked timing again.
no start. so I checked that the carb was getting fuel, yes! Check timing again 3 times. Car is getting spark and fuel, air. nothing, not even a back fire. good composition in all cylinders. Any ideas. Thanks |
05-27-2016, 09:42 PM | #2 |
Re: 1931 Model A not starting
I suspect that you are not getting something right in setting the timing. Was this the first time you've set timing? What directions are you following to set the timing?
Just my preference but I suggest going back to the original set up for points. The modern points seem to cause a lot of grief for folks.
Dave / Lincoln Nebraska |
05-27-2016, 09:50 PM | #3 |
Sorry to hear you installed so many parts. Most times, if the car ran when parked, all that's needed is air in the tires, charge the battery, may need fresh gas, and may need to clean the points. Hope you save the other parts.
Pull the choke, turn the engine over a couple revs, then see if gas drips out the carb. |
05-27-2016, 09:59 PM | #4 | |
Anyway, look here http://www.fordbarn.com/forum/showpost.php?p=1280509&postcount=4 and the same thing worded differently, http://www.fordbarn.com/forum/showpo...87&postcount=4
05-27-2016, 09:59 PM | #5 |
Thanks for your help, It has new gas and new points. The the directions I'm following is abarnyard.com/workshop/timing.htm
05-27-2016, 10:03 PM | #6 |
Thanks |
05-27-2016, 10:05 PM | #7 |
I'm getting good spark.
thanks |
05-27-2016, 10:14 PM | #8 |
You http://www.fordbarn.com/forum/showpo...87&postcount=4 need
1) fuel 2) Compression 3) Spark 4) at the right time Where are you testing spark? Is it getting to the plugs? Have you removed a plug and seen a spark at the gap? What are your gaps? My guess is still on the timing?
05-27-2016, 10:16 PM | #9 |
Badly flooded maybe?
Try cranking it with the throttle full open/accelerator to the floor(no choke!) and see if you get it to fire....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-27-2016, 10:21 PM | #10 |
Yes, me to. I'll give the farmbarn timing a go.
Thank again |
05-27-2016, 10:24 PM | #11 |
You say you have spark, compression, and gas, so the only thing left is...............is the spark occurring at the right time. Try to turn the rotor with your fingers. If you can, then the screw isn't holding the points cam tight.
05-28-2016, 10:01 AM | #12 | |
