Old 03-23-2017, 07:15 AM   #1
larry harding
Default engine pans
do most people run engine pans on their a ? i'll bet a lot of them got taken off for repairs over the years and never put back on. i have a set i picked up at a swap meet and am debating weather or not to put them on. i have the float a motor which allows the engine to move different from the frame, is that not going to flex and break the tabs on the pans?
larry harding is offline   Reply With Quote
Old 03-23-2017, 08:14 AM   #2
Ray64
Ray64's Avatar
Default Re: engine pans
Mine did
Ray64 is offline   Reply With Quote
Old 03-23-2017, 08:16 AM   #3
Bulligen
Bulligen's Avatar
I don't think you would have to worry too much about the fact you have the float a motor mounts. I never had the pans on my A , however I remember reading an article about the cooling improvement they were meant to provide. I thought the intent was to funnel the air from the radiator out through the back of the engine compartment?
Bulligen is offline   Reply With Quote
Old 03-23-2017, 08:40 AM   #4
Lona
Lona's Avatar
I have pans on mine with float-a-motor mounts with no problems. Before you put them on, suggest you paint them with a fuel proof paint, especially on the carb side. Don't ask me how I know.
Glen
'31 Model A Deluxe Roadster
'31 Chrysler Model 70 Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 03-23-2017, 08:44 AM   #5
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Did Henry have them on his As as they came off the line?
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 03-23-2017, 09:09 AM   #6
art ebeling
art ebeling's Avatar
Yes, But my 31 pans were only made to be attached in three spots, at the rear to the oil pan and frame and only at the frame on the front. I believe it has been posted here before that they were only attached at the rear because the engine does not move around like it does at the front mount.
art ebeling is offline   Reply With Quote
Old 03-23-2017, 10:29 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
I don't know about most but I do. The reason for them most stated, is to allow air to flow better along the engine to the rear and then out, cooling better.
Old 03-23-2017, 10:57 PM   #8
cpf240
cpf240's Avatar
I've also read that they form part of the electrical ground path for the engine.
I saw it on the internet, so it must be true!
cpf240 is offline   Reply With Quote
Old 03-23-2017, 11:40 PM   #9
Mike V. Florida
An additional path to ground is never a bad thing.
Old 03-24-2017, 01:54 AM   #10
DougVieyra
DougVieyra's Avatar
Larry Harding, post $1: "do most people run engine pans on their a ?"
A poll recently taken by the U.S. Census Bureau found that 62% of all Model A owners have engine pans (plural) on their cars. 35% had no engine pans on their cars. 2% had an engine pan on the driver's side only, while 1% had a engine pan the passenger side only.
DougVieyra is offline   Reply With Quote
Old 03-24-2017, 04:04 AM   #11
RUNNERBUN
RUNNERBUN's Avatar
I looked for ages before i found an original pair at a swap. Was happy as pig in mud. I cleaned, repaired and painted them and fitted to the car.
I didn't notice any difference to the cooling.
I found them to be a nucience and often got in the way, so i took them off and sold them.
The righthand drive cars have a very cluttered engine bay and the last thing i needed was an engine pan making it worse.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 03-24-2017, 06:28 AM   #12
Mike Peters
Mike Peters's Avatar
We ran our roadster for years without pans, and those floorboards would really get hot on hot days. So last year I installed set and now it is much cooler on passenger and driver on hot days. This may sound counterintuitive, but that was our experience. And no, it never affected engine temps.
Mike Peters is offline   Reply With Quote
Old 03-24-2017, 08:14 AM   #13
JohnLaVoy
JohnLaVoy's Avatar
The electrical part is true. The pan creates the only real connection, the motor mounts all have movement. Just run a ground strap from the frame to the engine or transmission and you will create the ground connection that you need.
JohnLaVoy is offline   Reply With Quote
Old 03-24-2017, 08:31 AM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Chief said they filled up with MUD, when you backed up on MUDDY roads!
Bill Hatemud
"THE ASSISTANT GURU OF STUFF"
Old 03-24-2017, 12:32 PM   #15
CarlG
CarlG's Avatar
That pole left out the ones that have engine pans, but they are on the shelf in the garage, only to be installed "someday".
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-24-2017, 04:08 PM   #16
KMeredith87
KMeredith87's Avatar
That's exactly where mine are! I used to run them but with constant maintenance these days they seem to be more of a hassle then they are worth...
KMeredith87 is offline   Reply With Quote
Old 03-24-2017, 04:15 PM   #17
Gunmetal blue2
Gunmetal blue2's Avatar
My AA has two that fasten to the oil pan and three that fasten to the frame.
Gunmetal blue2 is offline   Reply With Quote
Old 03-26-2017, 11:58 AM   #18
johnbuckley
johnbuckley's Avatar
Bill Hatemud
Bill, Is it you or your dog that always thinks the same as me??
Pans kept the mud off engines on dirt roads in the 1930s
Engines should be earthed properly, don't rely on pans alone If you need pans to aid cooling there's something else wrong with your system
johnbuckley is offline   Reply With Quote
Old 03-26-2017, 08:17 PM   #19
BILL WILLIAMSON
One Guy said, "I can't get the L/H one on from the top"----"Well, dummy, put it on from the BOTTOM"----"OK"!
I think the pans help to make a finished look to the engine bay!
Bill W.
Old 03-26-2017, 08:29 PM   #20
jm29henry
jm29henry's Avatar
Henry tried to make his car more cost effective and he found no value to the fan shroud.If Henry though he could save money and did not serve a purpose he would have eliminated them . Just my thoughts !!!
jm29henry is offline   Reply With Quote
