03-26-2017, 10:43 AM | #21 |
Re: Carburetor, starvation, newbie asks help
Will the car run at certain speed [ say 35-40] and then die at a higher speed [45 or over] ? If so, that still sounds like a fuel flow issue.
Just loosening the fuel cap and going for a ride, or, reaching thru the windshield once it starts to die and opening the fuel cap will rule in or out the fuel cap. I know you said it was good, but, they can fool ya. Sediment plugging the inlet can be a royal PITA too. The other info is good. There are quite a few issues that can cause your problem. |
03-26-2017, 11:26 AM | #22 |
Remove the carb drain plug, turn on the gas & let it drain for quite awhile into a container & see if the flow is CONSTANT. You can also see if there's water in the gas.
Bill Test
03-26-2017, 12:36 PM | #23 |
Many thanks for the recommendations and tips...I'm learning.
It dies at idle and at 25-35 mph speed. I even drove with the gas cap off. Turning the choke rod a bit ccw also caused back firing at the muffler. I'll remove the drain plug today. I removed the tube at the carb and the fuel flows out consistently steady. Haven't investigated the float, but will do so after I search the Forums for instructions on taking it apart and reassembly. I like the truck although it frustrates me. I really would like to convert back to 6 volt for the sake of perceived originality but I don't know how. I live near Fort Wayne IN, perhaps an experienced Model A'r is nearby. |
03-26-2017, 01:05 PM | #24 |
sounds like a lean mixture, you might have a leaking intake gasket, or carb gasket.
Thread Tools | |
Display Modes | |
