Old 06-29-2015, 04:19 PM   #1
Richard/Ca
Richard/Ca's Avatar
Question Armored around ign. cable
I am just wondering if any one cuts the armor around their ignition cable to make a lot easier to install. And if do they how much? I am sure no one wants to whack up an original one. Right!
Richard/Ca is offline   Reply With Quote
Old 06-29-2015, 04:22 PM   #2
Mitch//pa
Default Re: Armored around ign. cable
i know a guy that wanted to saw-zaw his water pump in half so he didnt have to mess with the radiator....
Old 06-29-2015, 09:03 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
If you want something easier just buy the thin repro cable and switch. I wouldn't damage original parts to make some job easier.
Old 06-29-2015, 10:17 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Thet guy shuld dump his Model A hobby & do woodwork! He ALREADY has a SAW
SA Dad
"THE ASSISTANT GURU OF STUFF"
Old 06-29-2015, 10:32 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Right!!
I have seen where someone has opened up the clamp by filing a hex shape so it would fit over the head nut with a friction fit so as to not have to remove the nut. As I posted before, a working POP out can go for as much as $400.00.
Old 06-29-2015, 11:15 PM   #6
Richard/Ca
Richard/Ca's Avatar
I have heard of people doing it before but not to and original. Just thought I would ask. sorry I out of here.
Old 06-30-2015, 02:15 PM   #7
BILL WILLIAMSON
Long ago, I've seen a cork, with a nail driven through it, then "screwed" into the dist. hole & the wire just wound the nail!!!
Bill W.
Old 06-30-2015, 02:18 PM   #8
2manycars
2manycars's Avatar
I use a modern look alike switch from Brattons, and I cut the cable housing short, so it looks correct under the hood, but is not in the gas tank tunnel making noise. It is easier to install.
2manycars is offline   Reply With Quote
Old 06-30-2015, 03:53 PM   #9
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Richard YES,. Ron Ehrenhofer rebuilds originals and always cuts them to make two parts, easy to install and remove and no one can tell...
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-30-2015, 04:38 PM   #10
BILL WILLIAMSON
It's A GREAT FREEDOM, to do things like we WANT to do them!!!
Bill W.
