10-23-2013, 05:56 AM | #1 |
Motometer Wings
Hi Guys
Just wanted to find out....what is the correct way for Motometer Wings to sit? The tips of the wings curve down. Do they point to the front of the car or do they point towards the windscreen? Any pics would be greatly appreciated. Basil |
10-23-2013, 07:06 AM | #2 |
Re: Motometer Wings
tips of the wings point to front of the car
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
10-23-2013, 07:09 AM | #3 |
Re: Motometer Wings
the tips of the wings point to the rear of the car and face up or the bird would be going backwards and grounded
10-23-2013, 07:24 AM | #4 |
Re: Motometer Wings
The scapulars and coverts face forward, as in flight. The trailing primaries face the windshield. Unless you want your wings to fly backward, which may ruffle some observers feathers.
10-23-2013, 12:52 PM | #5 |
Re: Motometer Wings
NO-NO-To the frunt!! Minerva sed SO! & she wuz FAST! Buster T.
10-23-2013, 01:00 PM | #6 |
Re: Motometer Wings
10-23-2013, 01:33 PM | #7 |
Re: Motometer Wings
dag i fly backwards all the time damn
i think it looks better the wrong way Last edited by Mitch//pa; 10-23-2013 at 04:51 PM. |
10-23-2013, 09:05 PM | #8 |
Re: Motometer Wings
MY OP, no matter which way you put them they look wrong!
10-23-2013, 09:18 PM | #9 |
Re: Motometer Wings
Place them so that they apply downforce or else the front end will lift at speeds over 170mph.
10-23-2013, 10:01 PM | #10 |
Re: Motometer Wings
I place all of my car's radiator cap 'Wings' up-side-down, which pushes the car with a down-ward pressure. This helps keep the car 'grounded' when negotiating rutted dirt and gravel roads. When driving on smooth flat, straight paved roads, I reverse it, so that the wings help 'lift' the car, giving me better gas mileage.
__________________________________________________ _________________ insomniacshotrods (see 6 posts below) - aside from the optional side-opening of the water cap (I assumed you quickly 'slapped' it on your car for the photo to help demonstrate your point), I believe you DO have the correct mounting of the Winged Ornament. The way you have it is the way I have always seen it on cars. Following both convention and my own sense of 'how it should be done' - I installed my just like yours. Like a real birds wings (eagle or otherwise) the thick part is the 'leading edge' (as in an areoplane wing) - the foreward-most part, leading to the 'trailing edge' at the rear of the wing, thinning down as it goes. So the thin edge should be towards the car's windshield. Ofcourse the feathers are up. I realize that there are always going to be people who like to personalize their toys, lord knows I do - so up-side-down, backwards, painted, brass, chrome, nickle - it really only matters to the rooster who is 'struttin' his stuff'. To continue with my own personalizing, after a stint with the 'Wings', I came to think that I they over-stated the cap - I began to think that they were a bit too much 'Clutter', and removed them. getting back to just a Motor Meter. Later I removed even the MotorMeter, and remained with just a plain stock 'Eaton' radiator cap. So I transcended gaudy and returned to 'chaste'. It is called 'evolution'. Or perhaps, 'Getting Old'. Last edited by DougVieyra; 10-29-2013 at 02:10 AM. |
10-23-2013, 10:14 PM | #11 |
Re: Motometer Wings
A "BIG" thank you to all the members with the smart arse comments - you guys are my heroes!!
10-24-2013, 12:17 AM | #12 |
Re: Motometer Wings
I have always thought wings on a motometer were seen in the early to mid twenties ,ie. the Model T era?
The era adverts of the Model A do not usually feature them. Someone may prove me wrong in this. |
10-24-2013, 01:30 AM | #13 | |
Re: Motometer Wings
I have a file on my computer with over 200 vintage photos of A Models. I went through all of them and saw mostly standard flat caps, a few quails, a few motometers, two flying ladies, and a bowling trophy but not one set of wings! |
10-24-2013, 01:56 AM | #14 | |
Re: Motometer Wings
Bill W.
10-24-2013, 02:10 AM | #15 | |
Re: Motometer Wings
Just for the record....... http://imagehost.vendio.com/preview/...405622DW-4.jpg |
10-24-2013, 02:24 AM | #16 |
Re: Motometer Wings
My car had just a cap that matched the gas cap on it when i got it. I put on a locking rad cap and a moto meter i already had,but it was missing something so i got my wings ha. Used permatex 2 to seal the top of wings to moto meter ,then rubber gasket at bottom of wings,then a dab of permatex on the bottom of cap where it all goes through,then brass nut. No leaks. Had to research some pics to see which way the wings went. Still looks backwards or upside down or something. But gives it that old car feel to me.
10-24-2013, 07:53 AM | #17 |
Re: Motometer Wings
were they not designed after the bald eagle
10-24-2013, 10:22 AM | #18 |
Re: Motometer Wings
And it appears to open to the side instead into the paint of an open hood. |
10-24-2013, 10:34 AM | #19 | |
Re: Motometer Wings
Did you elect to place them to the rear (considered backwards by some) or to the front (considered backwards by others)? |
10-24-2013, 10:46 AM | #20 |
Re: Motometer Wings
skeezixx you need to turn your cap another 1/4 so the hinge is in the rear and maybe a small drop of blue paint to fill in your chipped radiator badge.
