09-16-2013, 01:46 PM | #1 |
Hand brake set up on juice brakes
Hey guys what have you used for the rear hand brake cable set up when converting to juice brakes? The later model 1940+ rear cable is much longer and would necessitate trimming and then replacing the factory made ends? Thanks for the help.
09-16-2013, 02:00 PM | #2 |
Re: Hand brake set up on juice brakes
How about cutting some out in the middle and then splicing it back together?
Charlie Stephens |
09-16-2013, 02:26 PM | #3 |
you can buy a universal cut to fit cable from Autozone/Advanced Auto. Its about $10 I think.
09-16-2013, 02:31 PM | #4 |
I used a Lokar cable kit with the stock e-brake handle.
09-16-2013, 02:34 PM | #5 |
I also bought the lokar cable, Denis do you have any pictures of yours?
09-16-2013, 03:37 PM | #6 |
it uses the stock cross shaft 2 new cables and 2 mounting brakets |
09-16-2013, 04:38 PM | #7 |
I cut the original cable in the middle and fabbed a set of connectors using a threaded end that fits into cross shaft end. Easy to adjust.
09-16-2013, 05:19 PM | #8 |
+1 for Klings kit. Easy to instal ,reliable. I assume you have 39-48 backing plates.
John |
09-16-2013, 11:21 PM | #9 |
I made a new connector rod from the hand brake handle threading through the center crossmember
...and used split cable on turnbuckles to adjust side to side |
09-17-2013, 11:45 AM | #10 |
russ, nice work. bob
09-17-2013, 12:00 PM | #11 |
Russ that is a nice set up.
John |
09-17-2013, 06:36 PM | #12 |
Russ,could you post a picture of the rear tranny support. Looks like a F150?
09-17-2013, 09:42 PM | #13 | |
I did nothing to the tranny setup but re-mount it into my '29 cabriolet's frame. I think the F150 conversion is originally from Miss Vicky (on Ford Barn), but am not certain. I bought a doner car for the running gear in order to speed my getting my cabriolet on the road sooner than later. I was comfortable with the modifications I "inherited" generally, but had to clean up a few details. The hand brake link was originally made from all-thread, and looked awful in my eyes. It can be seen in the photo above. |
