06-24-2014, 12:36 PM | #1 |
1938 Ford Flathead V8 questions
1. For my Oil bath air cleaner do I use just a 30 weight motor oil?
2. For transmission and differential do I use standard type oil in use today for those or is there a certain weigh/type I should be using? 3. Not related to the motor, I have four pull knobs above /around the radio. One is the choke, one opens an ashtray, and one is a cigarette lighter. The fourth one is across from the choke and above the cigarette lighter. What is that for, doesn't seem to do anything and nothing feels attached to it when pulled. Sorry if these seems like stupid questions, but this car is in great condition and I do not want ruin it by doing something incorrectly. |
06-24-2014, 12:38 PM | #2 |
Re: 1938 Ford Flathead V8 questions
The knob above the cigarette lighter is the throttle knob.
06-24-2014, 12:52 PM | #3 |
ok like a cruise control. so it is disconnected I guess for safety reasons. I could see that causing a problem in a panic, lol. Thanks for the info.
06-27-2014, 05:38 PM | #4 | |
For your transmission and rear axle, get GL-4. Do NOT get GL-5 gear oil. The additives in GL-5 can attach the brass parts in your transmission. I have to go to NAPA to find this in my area. 80W-90 is fine. If you are driving in really hot weather you can go to 85W-140. |
06-27-2014, 08:33 PM | #5 |
You should NEVER use a throttle as a cruise control, that was/is not its intended use.
Imagination is more important than knowledge. |
07-24-2014, 08:55 PM | #6 |
07-24-2014, 10:28 PM | #7 |
If you have a pto off your transmission it's more useful too.
07-24-2014, 10:35 PM | #8 |
