Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 12-10-2020, 06:56 PM   #1
frederic
Default Suggestions on installing heater hose fitting
going to install a metal heater hose adaptor/fitting into the front lower radiator hose. other than making a nice tight hole does one use any type of sealer on the flat surfaces
thanks a bunch
Frederic
frederic is offline   Reply With Quote
Old 12-11-2020, 12:04 AM   #2
Charlie Stephens
Default Re: Suggestions on installing heater hose fitting
Sorry I can't help but would like to point you to the correct forum: https://www.fordbarn.com/forum/forumdisplay.php?f=4
You posted in an area intended for questions to the editor. People seldom read or respond to it.
Charlie Stephens
