Go Back   The Ford Barn > The Swap Meet > For Sale > Late V8
Old 10-22-2014, 09:04 AM   #1
DetroitMotion
Default 57 58 59 60 ford fullsize front disc brake conversion
City: Detroit
State: MI
Price: 499
This is a BRAND NEW IN BOX Tom's Classic Brake kit. Never installed it on my car and need it gone.
1957-63 FORD FULL SIZE GALAXIE FRONT DISC BRAKE CONVERSION. THIS IS A COMPLETE KIT TO CONVERT YOUR FULL SIZE FORD FROM DRUM BRAKES TO DISC BRAKES. YOU WILL RECEIVE WITH THIS KIT;
  • 1 POWER BRAKE BOOSTER WITH FIREWALL BRACKETS AND CLEVIS ROD
  • 1 DUAL BOWL MASTER CYLINDER
  • 2 CALIPERS WITH PADS AND MOUNTING BRACKETS
  • 2 RUBBER BRAKE HOSES
  • 1 PROPORTIONING VALVE WITH BRACKETS AND LINES
  • 2 ROTORS drilled and slotted with an anodized finish
  • ALL BEARINGS, SEALS, AND HARDWARE
THIS KIT REQUIRES 15" DISC BRAKE WHEELS.
YOU WILL HAVE TO RE PLUMB YOUR EXISTING BRAKE LINES TO WORK WITH THE NEW PROPORTIONING VALVE OTHERWISE THERE IS NO MODIFICATIONS NEEDED. THIS KIT IS A DIRECT BOLT ON.
DetroitMotion is offline   Reply With Quote
