04-11-2012, 07:24 PM | #1 |
Brake Problems.
This past Saturday, I went for my first ride this year. When I was leaving the driveway, which goes uphill just a little, my right rear brake locked up and then released on its own. Does anyone have any reasons that this would be happening or any positive suggestions ? We have checked the brakes and it isn't getting hot, anymore than the rest of them, after driving around for awhile.
04-11-2012, 07:45 PM | #2 |
Re: Brake Problems.
Could it be your parking brake that may not be releasing?
Fred Kroon 1929 Std Coupe 1929 Huckster |
04-11-2012, 08:03 PM | #3 |
Re: Brake Problems.
I've seen a couple do that and one was mine. It was E-brake lining problems both times. When I bought my 29 Tudor it had one E-brake lining and band missing, and the other side had the lining held on by one rivet.
04-11-2012, 08:48 PM | #4 |
Re: Brake Problems.
Thank you for your responses, I will check into the E-brake.
04-11-2012, 09:32 PM | #5 |
Re: Brake Problems.
Jamie86 , This would be a good time to check the E brake carrier . There are at least three different carriers . 1 non reinforced 2 reinforced and, 3 reinforced with ears to keep band on carrier . If band slips off it wull lock up brakes . Bubby Sharp in KY
04-12-2012, 08:50 AM | #6 |
Re: Brake Problems.
04-12-2012, 05:24 PM | #7 |
Re: Brake Problems.
Jamie, I had the same problem and it turned out to be that my clevis pin fell out of the e brake arm. either that or i forgot it but i will not admit that!
