Old 02-10-2016, 02:48 PM   #1
frederic
Default Too much oil ??
I put too much oil in engine. shows up over the "FULL" sign on dipstick. Not Full Line but the word FULL. maybe a quart or quart and half. Iam taking some out but just curious as to what happens when too much oil is put in. Does it affect running or carb or ???
thanks
Frederic
frederic is offline   Reply With Quote
Old 02-10-2016, 02:54 PM   #2
30-9
Default Re: Too much oil ??
I would think it depends on year of car. 39/40 have codder pin in center of pan for relief of too much oil.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 02-10-2016, 02:57 PM   #3
JSeery
JSeery's Avatar
No idea what this is referring to? The cotter pin in the flywheel/pressure plate area to allow drainage of that area?
But to answer the original question, most people find than the marks on the dipstick are off on the too little oil side, somewhere in the 4qt range vs 5gt range. With too much oil in the system there is a chance of the crank rod throws hitting the oil when the engine is running. In a high performance engine this is a bad thing and a lot of steps are taken to keep the oil off of and away from the exterior surface of the crank . I'm not sure how big an issue it is in a normally driven stock engine. On an early engine if it doesn't have a rear seal it can blow oil past the rear air lock.
Old 02-10-2016, 03:17 PM   #4
30-9
I thought the cotter pin allows over filled oil to drain out before it can get to the clutch. I made an error it's knot in the pan but logic is still the same - no?
Thanks - 30-9
1939, 1940
Old 02-10-2016, 03:29 PM   #5
Scott H in Wheaton
Scott H in Wheaton's Avatar
not for over-filled oil, for oil that leaked into that area. Cotter pin in the hole would jiggle as you drive down the road and keep the catch pan drained.
Scott H in Wheaton is offline   Reply With Quote
Old 02-10-2016, 03:30 PM   #6
Scott H in Wheaton
Over-filling by a quart won't affect the running, but it could potentially slow the engine if the crankshaft is dragging through the oil.
no way would it get to or affect the carb at all
Old 02-10-2016, 03:39 PM   #7
Lawrie
Lawrie's Avatar
Over fill will effect the engine,too much oil getting slung around will glase the cylinder walls,ask me I know.
Lawrie
Lawrie is offline   Reply With Quote
Old 02-10-2016, 06:08 PM   #8
frederic
Thanks People I have drained it to proper level but was just curious what would/could happen.
Old 02-10-2016, 07:10 PM   #9
john in illinois
john in illinois's Avatar
Rumble Seat addressed this oil capacity question in the v8 tech papers. Interesting read.
http://www.flatheadv8.org/rumblest/oil.pdf
John
john in illinois is offline   Reply With Quote
Old 02-10-2016, 09:21 PM   #10
JSeery
JSeery's Avatar
There have been several threads on this topic and the general consensus is that the Ford specifications call for 5 qts. No idea why the dipsticks are all marked a quart low!
Old 02-11-2016, 08:55 AM   #11
john in illinois
This is quite a Ford mystery. JS how many quarts do you use in a 59 not counting a filter?
John
Old 02-11-2016, 09:14 AM   #12
JSeery
JSeery's Avatar
John
Five qts, and remark the dipstick if it is off.
Old 02-11-2016, 09:42 AM   #13
JonC
When I built my motor in my P/U I needed to build a new dipstick to clear the fenton headers. I welded a rod to the cut off original dipstick put in five quarts and marked the level, runs fine.
JonC is offline   Reply With Quote
Old 02-11-2016, 11:03 AM   #14
V12Bill
V12Bill's Avatar
Several years ago I had a Craftsman riding lawn mower. I had my teenage helper change the oil . He didn't know the difference between 3 pints and 3 quarts and refilled the crankcase with 3 quarts of oil. within 20 minutes, the engine seized. Too much oil foams and foam is air mixed in with the oil.
The oil pump pumps a liquid, not air and the engine starves for oil. Yes too much oil can be bad for your engine. How much is too much? Start by adding one quart of excess oil. Run engine and then add another quart......
V12Bill is offline   Reply With Quote
Old 02-11-2016, 05:26 PM   #15
El Rat
If you fill the pan (off the engine) with 4 qt. water you will not put in 5 quarts without a filter. I run the piss out of my 46AB in a super nice 38 coupe with 4 quarts of 50 wt. racing oil!
El Rat is offline   Reply With Quote
Old 02-11-2016, 09:16 PM   #16
Kahuna
Kahuna's Avatar
El RAt
I did that exactly when I built my engine. I made sure the pan was at the "in car" angle, then put 4 qts of kerosene in the pan. The 4 qts filled the sump (59 type) perfectly. I then figured that with a short filter (95% oil system), and what ever oil stays accumulated in the crank and lifter valley, that 5 qts would be perfect. And it is.
Kahuna is offline   Reply With Quote
