06-20-2016, 02:02 PM | #1 |
1957 ford fairlane
anybody no were the wires go to from inhibiter switch. they wernt there. doing rewire
06-20-2016, 02:03 PM | #2 |
Re: 1957 ford fairlane
06-20-2016, 02:08 PM | #3 |
anybody no were the wires go to from inhibiter switch. they wernt there. doing rewire neutral safety switch
06-20-2016, 03:15 PM | #4 |
Inhibitor switch = neutral safety switch? That goes from the back of the ignition switch start terminal to the NSS from there it goes to the solenoid.
06-20-2016, 03:50 PM | #5 |
Depending on the location of the battery under the hood the two larger 'battery' and 'starter' cables may be reversed, it doesn't matter.
However, the two smaller wires for 'S' and 'I' must be connected as shown. 'Start' power from the ignition switch routes from the 'start' position of the key switch, thru the NSS, then to the 'S' terminal of the solenoid. . Last edited by dmsfrr; 06-20-2016 at 03:58 PM. Reason: add photo |
06-20-2016, 04:01 PM | #6 |
06-20-2016, 04:09 PM | #7 |
If the starter is/was already working some of the original wiring may(?) still be in place and the connections for the neutral safety switch were bypassed / jumpered together under the dashboard somewhere.
