Old 04-27-2020, 09:38 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Things That Vibrate
In your opinion, what are the most annoying things that vibrate, shimmy, shake and tamp in the Model "A"?
I am working on a presentation about vibrations in the Model "A," and I want to be sure I discuss the most annoying ones, so your comments will be of help.
Bob Bidonde
Old 04-27-2020, 10:20 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Things That Vibrate
Doors rubbing on body, Springs if not oiled,CCPU Tail gate,!
www.whidbeymodelaclub.com
Old 04-27-2020, 10:26 AM   #3
30 Closed Cab PU
Bad seal in the front widow, window rattles.
30 Closed Cab PU is offline   Reply With Quote
Old 04-27-2020, 10:32 AM   #4
eagle
eagle's Avatar
The front windshield squeeks where it touches the windshield frame to body. A little vaseline takes care of it for a while. Kind of a fingernail on chalkboard sounding squeek. :0
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 04-27-2020, 10:40 AM   #5
katy
katy's Avatar
Rear view mirrors.
Old 04-27-2020, 11:01 AM   #6
jb-ob
Passengers.
jb-ob is offline   Reply With Quote
Old 04-27-2020, 11:29 AM   #7
Roxo
Roxo's Avatar
Originally Posted by jb-ob View Post
Passengers.
I wonder does this include the wife?
Roxo is offline   Reply With Quote
Old 04-27-2020, 12:26 PM   #8
Davew
Davew's Avatar
Mine is the top of the drivers side front window.. I have tried tape, and grease nothing works. Also leaks a little water. The back tray on my coupe vibrates where it meets the metal part. really annoying. Guess thats part of what makes them interesting.
Davew is offline   Reply With Quote
Old 04-27-2020, 02:11 PM   #9
DNLs1930
DNLs1930's Avatar
The worst noise I HAD was the muffler "heat shield" that had cracked on one side and clanked with every road bump!!! Second is a set of brake rod "anti rattlers that RATTLE because they cracked at the mounting point. I have net gotten then changed yet... Got a set of the '31"wire" type anti rattlers as a replacement based on many reviews and experiences from Ford Barn members.
I probably have many of the other noises but just not able to hear them over the first two... but those issues will soon be history!!
DNLs1930 is offline   Reply With Quote
Old 04-27-2020, 02:41 PM   #10
Conaway2
Conaway2's Avatar
The clutch pedal vibrates against the floorboard when I shift into 3rd gear. I usually stop it by putting my left foot under the pedal to hold it still.
Conaway2 is offline   Reply With Quote
Old 04-27-2020, 02:48 PM   #11
Big hammer
Steering column buzzing, it makes your hands numb! Not the horn rod but the column, mines the column drop to column connection.
get a bigger hammer tap done
Old 04-27-2020, 04:14 PM   #12
Tacoma Bob
Tacoma Bob's Avatar
My wallet coming out of my pocket when buying Model "A" parts. LOL
Tacoma Bob is offline   Reply With Quote
Old 04-27-2020, 06:40 PM   #13
chrs1961815
chrs1961815's Avatar
Horn rod and the frame because of kmproper flywheel alignment.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-27-2020, 09:22 PM   #14
1crosscut
1crosscut's Avatar
Original tail pipe clamp. Mostly on deceleration.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 04-28-2020, 01:22 AM   #15
Bill G
Bill G's Avatar
There is a @#*&$ squeak that I installed! Top side rail wood in my Tudor. Apparently I missed just a teensy bit of anti squeak and it is intermittent enough to drive me nuts but my wife and others who all have better hearing than me .... don’t seem to mind or care. But I do!
Bill G is offline   Reply With Quote
Old 04-28-2020, 01:46 AM   #16
Tudortomnz
Tudortomnz's Avatar
As others have noted, front windshield frame to body & door glass area & also I get squeaks from the metal floor plate around gear lever & hand brake.
Tudortomnz is offline   Reply With Quote
Old 04-28-2020, 07:12 AM   #17
30 Closed Cab PU
More of a squeak, not a rattle
I use Bees Wax on door rubber bumpers, and usually lasts a driving season. I have an old toilet wax ring that I cut off piece, put in a zip lock baggy, and store in my truck.
Old 04-28-2020, 07:13 AM   #18
30 Closed Cab PU
I get this too, what do you do?
Old 04-28-2020, 07:44 AM   #19
History
History's Avatar
Bob, it's all that stuff you carry for "just in case".
I hope to tag mine here soon and find out what what noises I have on the hiway. Oh, and see if my jb welded block holds.
Mr 30 closed cab, I have a used wax toilet seal/ring I'll send if you if you want?
History is offline   Reply With Quote
Old 04-28-2020, 08:26 AM   #20
GPierce
GPierce's Avatar
Throttle rod against the GAV rod.
GPierce is offline   Reply With Quote
