Go Back   The Ford Barn > The Swap Meet > Wanted > Late V8
Old 01-05-2014, 01:43 PM   #1
wi0v
wi0v's Avatar
Default 1956 Mercury Shift Indicator
City: Chadron
State: Ne
Item wanted is the shift position indicator for a 1956 Mercury with a Merc-A-Matic transmission. This indicator fits on the steering column and is made of plastic. The small missing part of the indicator holds a slide switch for the horn. Apparently pressing too hard on the horn ring breaks the old brittle plastic.Have attached a photo of the damaged inticator
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
wi0v is offline   Reply With Quote
Old 01-05-2014, 07:57 PM   #2
clcrown
Default Re: 1956 Mercury Shift Indicator
Gary I have a complete steering shaft with tube from a 56 merc,i will check it in the next couple days to see if the part you need is not broken Carl
clcrown is offline   Reply With Quote
Old 01-06-2014, 03:21 PM   #3
wi0v
wi0v's Avatar
Carl:
You're right the indicator for a 55 is different than a 56. Don't know about the Fords, maybe someone that has a Ford will let us know. The Ford-A-Matic and the Merc are basically the same Trans so maybe the Ford indicator is the same. Again Carl thanks for looking, I really appreciate it.
Gary
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
Old 01-06-2014, 07:43 PM   #4
clcrown
Originally Posted by wi0v View Post
Carl:
Gary
Gary The Ford will not work it is entirely different,i will send you a PM and give you the name of a guy that probably has the one you need Carl
Old 01-23-2014, 11:57 AM   #5
wi0v
wi0v's Avatar
Still looking for the Shift Indicator at a reasonable price. Received one reply but way more than this old man can afford, so if someone has one at a reasonable price let me know.
Gary
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
Old 03-12-2014, 09:16 AM   #6
wi0v
wi0v's Avatar
Still looking for the shift Indicator
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
