Old 04-22-2019, 02:50 PM   #1
wi0v
wi0v's Avatar
Default 56 Mercury Montclair
My 312 has a Carter Carb and the double vacuum advance. I removed the distributor six years ago. Now need help on routing the vacuum lines. One goes from the distributor to the manifold port below the carburetor, to either the top or bottom port on the distributor? The other vacuum line, I have (unfortunately) no idea. I sure could use some help! I have some Tbirds used the same system, but I am not sure.
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
wi0v is offline   Reply With Quote
Old 04-22-2019, 03:02 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 56 Mercury Montclair
This diagram might help you out? But it is for a Holley, not Carter...
Old 04-22-2019, 04:46 PM   #3
scicala
scicala's Avatar
The diagram supplied by Dmsfrr is good for the Carter WCFB on '56 Merc's too. The outer diaphragm goes to the brass fitting at the back/bottom of the carb(manifold vacuum), and the inner diaphragm goes to the front of the carb (ported/venturi vacuum).
Sal
scicala is offline   Reply With Quote
