01-03-2017, 08:46 PM | #1 |
Body bolts
I have a body bolt kit from Snyder's, but I am a little confused about what is what. I didn't document the originals, unfortunately, so I can't go by that. So, I know the carriage bolts go in the square holes in the front end, but the rest confuse me. Especially the short, narrower bolts. I assume the four mid-size bolts go in the cross members' holes. Can anyone tell me where these all go? Thank you. Oh, it is a '29 Fordor, body style 60-C, if that changes anything.
I can't wait to do more of this. https://www.youtube.com/watch?v=a2IjBUESAEQ |
01-03-2017, 09:29 PM | #2 |
Re: Body bolts
Judging standards lists the bolts for each body.
01-03-2017, 09:37 PM | #3 |
Re: Body bolts
The 2 smallest bolts go up at the cowl.
The 2 larger bolts go at the back of the body and drop down into the rear cross member. The other 4 bolts go in between, probably 2 on each side. |
01-03-2017, 09:59 PM | #4 | |
Re: Body bolts
Hoping to get my body on this weekend.
11-20-2018, 06:19 PM | #5 | |
Re: Body bolts
I am planning to eventually put the body of my 1929 Special Coupe back on the frame. I have a body bolt set and it makes sense until I saw the four carriage bolts seen above the eight body bolts in the package. What are these for? I wish I had paid more attention to body bolts and blocks when I took my car apart more than five years ago. |
11-20-2018, 07:18 PM | #6 |
Re: Body bolts
These bolt holes are pictured from the front to rear, and numbered as such. Locate the 2 and 3 position in the cowl area on either side of the frame on a tab or support, outboard of the frame rail. |
11-24-2018, 10:38 AM | #7 |
Re: Body bolts
The Model A as Henry built it pg30-31 has the listing for each frame hole size location. Its by G DeAngelis
www.whidbeymodelaclub.com |
