Old 05-04-2015, 10:53 PM   #1
CaceyB
CaceyB's Avatar
Default What is this?
I cannot find this part in the shop manual. It was on the spindle when I was disassembling the car. I think it was between the inner bearing and the base. I seem to have only found one so I don't know if this was supposed to be there or if someone else added it.
Hopefully someone can tell me what it is.
Thank you,
Cacey
I can't wait to do more of this. https://www.youtube.com/watch?v=a2IjBUESAEQ
CaceyB is offline   Reply With Quote
Old 05-04-2015, 11:14 PM   #2
jax55
jax55's Avatar
Default Re: What is this?
This appears to be a grease slinger which sits between the inner bearing and the backing plate. There should be one on each side of the car.
This takes the place of an inner grease seal used on more modern cars.
jax55 is offline   Reply With Quote
Old 05-05-2015, 01:09 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
FRONT HUB INNER DUST SEAL looks a little different from what your picture shows but the location is correct.
Old 05-05-2015, 03:29 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Your part looks like the remains of a regular grease seal that someone installed in place of the factory seal. Here's a picture of my original seal. Notice the rings (grooves) machined in the outer surface.
Old 05-05-2015, 10:03 PM   #5
CaceyB
CaceyB's Avatar
The spindles I got to replace my worn ones look have that ring like yours does, Tom. I assume then I don't need to replace the seals I had?
Old 05-05-2015, 10:08 PM   #6
Tom Wesenberg
Right, just do it the original Ford way and you'll be fine.
