11-19-2023, 08:39 PM | #1 |
1936 3 speed trans for parts
I have an original 3 speed trans from a 36. Found with watery sludge inside. Internals are mostly junk. Case is good. Is there any value in this before I scrap it?
Thanks |
11-19-2023, 09:17 PM | #2 |
Re: 1936 3 speed trans for parts
11-20-2023, 03:06 AM | #3 |
U joint & clamshell. Maybe.
Alan |
11-20-2023, 06:31 AM | #4 |
The case would be the 48-7006 type and those are practically the same as the 78-7006 cases (as long as the transmission is being built with the 28 tooth cluster gear). Strip out the gears and check the case for cracks or severe wear inside at the rear thrust surface for the cluster gear. We save and use good 48- cases all the time.
12-22-2023, 12:41 AM | #5 |
Are these all the same or is the v8 60 shell unique? |
