10-29-2018, 01:10 PM | #1 |
Re-torque head
How do you re-torque no.1 headbolt ? Meaning the which is 'under' the distributor, without removing the dist. First ?
10-29-2018, 01:23 PM | #2 |
Re: Re-torque head
https://www.brattons.com/head-nut-torque-tool.html
That's what Brattons sells to do the job. A crows foot would probably work too. I've always just removed this dist. though. |
10-29-2018, 01:25 PM | #3 |
Re: Re-torque head
I take the dist. out. Not difficult. I mark the dist. cam to the plate as a reference for a double check when putting the dist. back on. As long as the cam screw is tight, the dist./motor timing will not change.
There may be other methods, or perhaps a special tool, I do not know. Last edited by 30 Closed Cab PU; 10-29-2018 at 01:26 PM. Reason: Changed cam nut to cam screw. |
10-29-2018, 03:28 PM | #4 |
Re: Re-torque head
10-29-2018, 03:38 PM | #5 | |
Re: Re-torque head
This is the way I have done it for almost 60 years and I’m to old to change. Not much extra work, and you can get a real wrench on that head nut. Enjoy. |
10-29-2018, 03:41 PM | #6 |
Re: Re-torque head
Charlie Stephens |
10-29-2018, 09:53 PM | #7 |
Re: Re-torque head
I have the special tool. It makes the job quick and easy.
10-30-2018, 12:18 AM | #8 |
Re: Re-torque head
10-30-2018, 02:19 AM | #9 |
Re: Re-torque head
Is there any significant difference in the tool sold by the major vendors? I'm asking because there is a bit of a price difference between them.
10-30-2018, 05:45 AM | #10 |
Re: Re-torque head
I have used the HF crawfoot and the head tool. I prefer the headtool. The headtool might be more accurate due to the design.
Brattons tool look very crude, you can get good deals on used ebay items. |
10-30-2018, 08:43 AM | #11 |
Re: Re-torque head
A crowfoot at 90° to the torque wrench will give the proper torque.
10-30-2018, 09:28 PM | #12 |
Re: Re-torque head
censored!
10-31-2018, 01:00 AM | #13 |
Re: Re-torque head
29er - thank you!
10-31-2018, 03:04 AM | #14 |
Re: Re-torque head
Ebay often has the correct tool, and even in Snap-On brand.
10-31-2018, 10:28 PM | #15 |
Re: Re-torque head
Should the retorquing be done when the engine is hot or warm or cold?
11-01-2018, 10:36 AM | #16 |
Re: Re-torque head
Cold.
11-01-2018, 11:30 AM | #17 |
Re: Re-torque head
11-01-2018, 08:35 PM | #18 |
Re: Re-torque head
You just can't have too many head nut wrenches.
11-01-2018, 10:03 PM | #19 | |
Re: Re-torque head
Yes
