Old 07-30-2013, 11:11 AM   #1
stouchton
stouchton's Avatar
Default Clutch cover hole??
Had a friend look at my A and tell me I needed to drill a 1/4" hole in the bottom of the clutch cover to let accumulated oil drain (and to also stick a cotter pin in it to keep from clogging). He told me it is in one of the service bulletins (I could not find it...).
So, after many hours searching I came up with nil. It makes sense to me to do it, looking at how it was built. Seems any oil passed by the slinger will collect and hit the clutch prior to getting high enough to lubricate the radius ball.
Just looking for some advice on this. I do have the complete service bulletins - maybe I just missed it?? Should the hole be drilled (is the theory right?)? And, if so - simply at the lowest point on the bottom?
stouchton is offline   Reply With Quote
Old 07-30-2013, 11:16 AM   #2
Larry Seemann
Default Re: Clutch cover hole??
There is already a hole like that at the bottom of the flywheel housing for that purpose. Or did I misunderstand the question?
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 07-30-2013, 11:28 AM   #3
newshirt
newshirt's Avatar
The cotter pin in the drain hole in the flywheel housing is placed there to prevent the hole [from] becoming clogged. The movement of the pin prevents any possibility of dirt or other foreign matter plugging up the hole.
Service Bulletins, page 218, second column, near the bottom
Ray White
newshirt is offline   Reply With Quote
Old 07-30-2013, 12:51 PM   #4
stouchton
stouchton's Avatar
Thanks Ray - I must have missed it.
Larry - Been under the car a couple times and never noticed a hole. The fellow who mentioned it to me also went under the car and said it wasn't there. I'm not sure if they were drilled at the factory or not.
I will read up on the service bulletin and crawl underneath and have a second look.
Did they put something different in the hole in 1931? I did notice what looked like a brass rivet on the bottom of the clutch housing. It seemed tight to the housing, and did not seem to have a place for oil to leak out. I figured it was for something mounting in the bottom of the clutch housing, for the life of me I am not sure what it would be.
Old 07-30-2013, 01:31 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
There should be a large cotter pin in the hole, with the round head inside the housing and the ends spread just a little. This will move around some and keep the hole from plugging up. If the cotter is missing, just make up something out of a coat hanger that you could bend enough to make it stay in the hole. The next time the tranny or engine comes out, you can then fix it the right way.
Old 07-30-2013, 01:54 PM   #6
stouchton
stouchton's Avatar
Tom - so I am gathering that the hole I am looking for is under 1/4" diameter and the cotter pin was inserted from the inside of the housing. Also - this hole would be directly on the bottom of the clutch housing - in front of the radius ball, correct? (didn't get to look at service bulletins yet).
I really did not see anything like that under mine - not even a hole.
Old 07-30-2013, 02:16 PM   #7
Mitch//pa
here is a pic of the bottom of the clutch housing
please excuse the bubble wrap lol
Old 07-30-2013, 02:20 PM   #8
stouchton
stouchton's Avatar
Holy Smokes! Thanks Mitch - picture is worth a thousand words!
Old 07-30-2013, 02:26 PM   #9
Mike in NRN IN
Mike in NRN IN's Avatar
Check out this thread on FordBarn -
While this describes the 'alignment' it also shows the hole in the flywheel housing quite well.
http://www.fordbarn.com/forum/showthread.php?t=34484
When I got my coupe and replaced the clutch, I found the hole clogged with dirt and no cotter pin.
I didn't know there was a hole, until I started cleaning things and reading the Les Andrews books.
If you say there is a brass plug in there, I would recommend drilling it out and working a wire / portion of coat hanger into the hole until you have a chance to pull the transmission out.
Mike
Mike in NRN IN is offline   Reply With Quote
Old 07-30-2013, 03:19 PM   #10
newshirt
newshirt's Avatar
You don't have something like this covering it, do you? This accessory attaches to the bottom of the flywheel housing, and will obscure the hole and cotter pin. Consider taking a photo of the bottom of your flywheel housing and posting it here.
http://www.snydersantiqueauto.com/4706
Ray White
Old 07-30-2013, 03:33 PM   #11
1931 flamingo
1931 flamingo's Avatar
Mine was "missing. I inserted the c/pin backwards and was able to spread the ends so it stays in.
Paul in CT
Old 07-31-2013, 08:52 AM   #12
stouchton
stouchton's Avatar
Crawled under her last night (no lift ) and lo and behold I've got a 3/16" hole
No cotter pin, but I can easily add that.
Thanks for your help. Should have paid more attention the first time I was under there. The hole was hard to see, felt it with my finger first then wiped the oil off and could see it.
Old 07-31-2013, 09:03 AM   #13
Napa Skip
Napa Skip's Avatar
And that - I guess - is the whole story...
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
