Old 01-07-2012, 11:04 AM   #1
1932BB
Default !933 Ford Intake Manifold (single barrel carb)
delete
1932BB is offline   Reply With Quote
Old 01-07-2012, 02:06 PM   #2
David J
David J's Avatar
Default Re: !933 Ford Intake Manifold (single barrel carb)
Fuel pump stand ? On a 33 ? . I see you put this where it belongs before the hall monitor busted ya . FWIW if you have a fuelpump stand on a 33 your intake has probably been modified .
David J is offline   Reply With Quote
Old 01-07-2012, 02:33 PM   #3
ken ct
Originally Posted by david j View Post
fuel pump stand ? On a 33 ? . I see you put this where it belongs before the hall monitor busted ya :d . Fwiw if you have a fuelpump stand on a 33 your intake has probably been modified .
good catch david. None on a 33. Ken ct. SO NO 33 FUEL PUMP.
ken ct is offline   Reply With Quote
Old 01-07-2012, 11:09 PM   #4
columbiA
Later fuel pump & stand wont work unless you remove oil filler pipe & cut off part of filler pipe boss.--Hard to find one that is uncut.
columbiA is offline   Reply With Quote
