02-10-2014, 03:00 PM | #1 |
Location: Keweenaw Bay, MI (Michigan's Upper Peninsula)
Engine Oil Drain Plug
Can anyone tell me what thread size is on the oil drain plug? I just drained the oil and went to put the plug back in and it would not tighten so, I took it back out and the threads on the plug were almost all gone! (repo) The threads in the pan look okay and I thought I would chase them with a tap first and install a new plug. My thread pitch gauge says 24 TPI and I am guessing it is 3/4" X 24 TPI. Hope this can be verified. Thanks!
02-10-2014, 03:15 PM | #2 |
Re: Engine Oil Drain Plug
New 3/4"X24 drain plugs are available at any of the vendors for a few bucks.
02-10-2014, 03:56 PM | #3 |
I have ordered a new drain plug. My question is what is the thread size so I can chase the threads in the pan with a tap.
Thanks |
02-10-2014, 03:57 PM | #4 |
This is what I use:
Magnetic Oil Drain Plug: Same as the regular oil drain plug except it has a magnet to grab any foreign metal objects floating in the oil that can cause damage. U.S.A. A-6730-M $3.75 / ea. (From Snyder's Catalog)
02-10-2014, 04:29 PM | #5 |
Depends if it is a 28 or 29-31 oil pan.
02-10-2014, 04:32 PM | #6 | |
www.whidbeymodelaclub.com Last edited by Gary WA; 02-10-2014 at 07:00 PM. |
02-10-2014, 04:46 PM | #7 |
It is a 1930 engine.
02-10-2014, 04:59 PM | #8 |
Thread size. See post #2. 3/4" X 24 again.
02-10-2014, 05:56 PM | #9 |
You could use a plumber's brush or some such round wire brush to clean the threads. I'm usually not a fan of using a tap because it might remove good metal. You could also use the thread gauge and just spin it around the threads to see if it pulls out some stipped thread. A fine pick such as a dental pick could also be used.
10-01-2022, 05:13 PM | #10 |
The wrench size for it is 15/16", Yes?
I mean for the new plug you can buy 3/4 24 thread. |
10-01-2022, 05:48 PM | #11 |
I always wondered if the magnetic plug would pick up babbit?
10-02-2022, 07:33 AM | #12 |
If I’m reading this correctly, it looks like tin is a major component of Babbitt. I’m thinking that a magnet will not attract fragments very well. Others may disagree. https://en.wikipedia.org/wiki/Babbit...y)?wprov=sfti1 Sent from my iPhone using Tapatalk |
10-02-2022, 03:15 PM | #13 |
Shew01, I was thinking the same thing.
