Old 12-22-2011, 02:48 PM   #1
MurphyJ
Default Leg room question
How much more leg room is there in a model a coupe than there is in a pickup?? I believe that the coupes have a seat fore and aft adjuster whereas the pickup seats have only one position.
Thanks for any input.
MurphyJ is offline   Reply With Quote
Old 12-22-2011, 03:18 PM   #2
Russ B
Default Re: Leg room question
I just compared my '29 closed cab to my '29 standard coupe. The top front edge of the seat bottoms were the same at about 9" back from the A pillar. The top front edges of the seat backs were about 1-1/2" different in distance back from the dash rail, 29-1/2" versus 31" for the coupe. Both do not have adjustable seats. That small distance difference for the seat back is significant for improving comfort on a multi hour drive.
Russ B is offline   Reply With Quote
Old 12-22-2011, 03:51 PM   #3
CarlG
CarlG's Avatar
To say nothing of the wear marks the steering wheel leaves on my shirt.
Old 12-22-2011, 04:07 PM   #4
Jerry in Shasta
Jerry in Shasta's Avatar
In my '30 coupe I cut about an inch and a half off the package tray. That let the seat slide back,and give more room for my 6'4" body. A small move, but it made a noticeable difference.
JB
Jerry in Shasta is online now   Reply With Quote
Old 12-22-2011, 04:26 PM   #5
Fred K-OR
Fred K-OR's Avatar
I have a 29 std coupe and I was able to adjust the back of the seat back, a couple of inches. The Ford service bulletins page 257 tells you how to do this. If you would like a copy of this page, PM me and I will try to send you a copy.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-22-2011, 06:49 PM   #6
RcT
On my '29 Coupe, I determined the former owner had done a poor job on the back seat cushion and had overstuffed it. I took it apart and saw none of the springs had been tied down. I uniformly tied all the springs about 2" and put in new batting on the seat cushion. All totalled I picked up about 2-1/2" of leg room... much better. As a guide, I looked at the interior pictures of all the coupes I could find on ebay and noticed that the bottom of the back seat cushion aligned with the welting on the door. I think it shows on my album pictures on my personal page. Well worth the effort and time involved.
Richard
RcT is offline   Reply With Quote
Old 12-22-2011, 08:05 PM   #7
eagle
eagle's Avatar
I am 6' 4" and I just didn't fit in my Fordor sedan. It wasn't safe either as my leg would get stuck under the steering wheel and I couldn't get to the brake. I made new seat to door post brackets and moved the whole seat back about 2.5 - 3 inches and bent the shifter to the right. It is very comfortable and easy to drive now. A pickup or coupe is nearly impossible to drive for me. There is so much leg room in the back seat of the Fordor that it wasn't a problem for the passengers when I moved the seat back.
Old 12-23-2011, 02:06 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Murphy,
On my '30 coupe, I cut 4" from the package tray, drilled out seat riser rivets and moved the WHOLE seat assembly back a full 4," WONDERFUL! and it looked like a factory job.
Can't do it on my '29 coupe without butchering it!
Took out stock cushions, cut 3/4" plywood panels for back & bottom, covered them with carpet, put piano hinge on front of bottom panel for tool acccess under seat. Mounting 2 curved back bar stool seats, with swivels I found at Bass- Pro Shop!
Go'nna look RACY! No alterations to the car at all,and it can be changed back to stock in 10 minutes. Keep watching, as I will be posting pictures.--Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-23-2011, 02:31 PM   #9
CarlG
CarlG's Avatar
Originally Posted by BILL WILLIAMSON View Post
...Took out stock cushions, cut 3/4" plywood panels for back & bottom, covered them with carpet, put piano hinge on front of bottom panel for tool acccess under seat. Mounting 2 curved back bar stool seats...
Wonder if this would work on a '31 CCPU?
Old 12-23-2011, 03:25 PM   #10
Patrick L.
Patrick L.'s Avatar
If I remember correctly, I think there is quite a difference between 28/29 and 30/31.. I think there is more room in the 30/31, but, then again, maybe not..
Old 12-23-2011, 03:28 PM   #11
CarlG
CarlG's Avatar
What I really remember is that there was a whole lot more room in my Model A's when I was a teen ager than there is now.
Old 12-23-2011, 03:33 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
My friend has a 31 widebed and the seat is very tight as well as uncomfortable because the seat back is so straight. I'll have to check another 31 to compare, but this one just doesn't seem right.
Old 12-23-2011, 08:28 PM   #13
BILL WILLIAMSON
Carl,
Yes, definately. The curved back of the seat is only about 1 inch thick, which gives you a lot of leg room and it has a nice angle for comfort. The foam filled bottom is about 3 inches thick, so you gain some headroom also. Bill W.
Old 12-23-2011, 08:33 PM   #14
BILL WILLIAMSON
Yes, the 30/31 coupes have quite a bit more legroom than the 28/29. Bill W.
Old 12-24-2011, 03:10 AM   #15
CarlG
CarlG's Avatar
Carl,
I will anxiously await the pictures.
Old 12-24-2011, 09:39 PM   #16
BILL WILLIAMSON
Carl,
Has Santa left yet?? My main question is: did you grow taller or thicker?? My dog told me to put the idiot grin, he says it is my official badge pic.
Have a great Christmas, Bill W. & Buster
Old 12-24-2011, 10:34 PM   #17
LukeDahlinger
For you 30-31 Pickup guys-
Snyder's makes a set of thinner seat springs that do a world of good increasing leg room. I ordered a set for my early '31 sometime back and while I haven't upholstered them yet, there is a noticeable difference in leg room when compared to the standard/original size springs that were in the truck when I got it. The seat cushion is a bit lower as well. Now my line of sight isn't even with the top of the windshield which is a good thing.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 03-07-2012, 01:07 AM   #18
BILL WILLIAMSON
btt
Old 03-07-2012, 08:10 AM   #19
Clydes 31 P/U
Don't know how I missed this thread before but Bill, that's an idea I'm going to put to use in my 31CCPU. Thanks
Clydes 31 P/U is offline   Reply With Quote
Old 03-07-2012, 09:04 AM   #20
lschultz
Hmmm I wonder why this is. Could it be that you got fat well lets just say gained some like the rest of us.
1931 Model A 4dr slant window
1958 & 1959 Cushman Eagle
2012 Victory Cross Country Tour
2009 Softail Custom (sons)
lschultz is offline   Reply With Quote
