11-09-2022, 12:26 PM | #1 |
6volt coil question.
HI guys can any one tell me the OHM range for the 6 volt ign. coil in a model A.I have a few spares and want to test them to see if they are keepers. thanks THE HOOCH
11-09-2022, 12:34 PM | #2 |
Re: 6volt coil question.
The primary side coil should be close to 1.5 Ohms.
11-09-2022, 06:41 PM | #3 |
The secondary should be about 10Kohms plus or minus 1K.
11-09-2022, 07:01 PM | #4 |
Keep in mind that an ohmmeter will tell you if its definately bad. But it won't tell you if its definitly good. You need a proper coil tester to do that. Here is a short video showing how mine works for testing coils and condensers.
https://youtu.be/7thA6UA5kbk |
11-09-2022, 07:06 PM | #5 |
And when they heat up they can start to break down too.
11-09-2022, 08:02 PM | #6 |
Just finished testing about 25 coils, majority were junk. Cold they almost all uniformly push a 6.5 on the 'Good' scale, but hot they fail @ 3.0 'Bad' ....translated, they will start your car but not bring you back home. (Herbrand 660 coil tester) It was suggested to me last evening, IF you find a 'good one', save it for shows but drive on a new repo. Your Mileage May Vary |
