09-18-2017, 03:57 PM | #1 |
FS electronic ignition
I keep saying the next time I have a problem with my electronic ignition I am going back to points. The coil got hot and car would not start. Hardly no spark. The module either works or not. Took the coil off the other A and now the car starts fine. Paid $44. for a new coil when a regular coil cost $15. I keep saying no more but I find myself paying the price....
09-18-2017, 04:00 PM | #2 | |
Re: FS electronic ignition
Sent from my SM-J700T using Tapatalk |
09-18-2017, 04:12 PM | #3 | |
The best ever ( havent seen a bad one ) is the Bosch Blue # 00012, not 12 bucks but could be the best money you ever spent .. https://www.amazon.com/dp/B001CO4WA2...505769111&sr=1 |
09-18-2017, 04:16 PM | #4 |
Electronic Ignition systems on a Model A are like having a pet rattlesnake......
one day.......
I noticed the harder I work the luckier I get! |
04-04-2018, 01:52 PM | #5 |
The Bosch Blue 00012 12 volts are I believe made in Brazil not Germany. Anyone have issues with these?
04-04-2018, 05:14 PM | #6 |
04-04-2018, 05:44 PM | #7 | |
04-04-2018, 06:24 PM | #8 |
I'd really like to hear about this too. I've yet to hear of anyone who has incorporated vacuum advance or retard--which is crucial--along with their centrifugal advance system. I set up my Pertronix and in-valve-chamber centrifugal advance with three clicks of retard left on the spark lever at tdc, so I can play the role of human vacuum retard and stop knocking at low rpms under load.
04-04-2018, 07:53 PM | #9 |
Yes it's has vacuum advance running off the vacuum port of the weber 32/36 carb (probably both centrifugal and vacuum) and averaging 25 plus mpg (fordor sedan). The distributor has around 28 degrees advance. The mechanical advance is not connected. I learned of this 25 years ago from the Nor Cal FAST club hill climbs. Charlie Yapp's front drive distributor uses a VW distributor. It's timed just like a Mallory Distributor. I've only looked under the cap a couple of times all of those years.
04-05-2018, 09:41 AM | #10 |
Something like this? http://www.cardone.com/Products/Prod...p=rock&jsn=540
04-05-2018, 11:02 AM | #11 |
I don't know why so many people have a problem with electronic ignition in a Model A. Electronic ignition has been around since the middle 70's and is very reliable. The Pertronix Ignitor II module is pretty bulletproof if installed correctly(dedicated ground from distributor to battery). After installation, your timing doesn't change EVER due to point block wear. In the rare instance that the module does fail(hasn't happened to me), it's easily changed on the roadside. A spare module cost less than the value of a spare distributor many Model A'ers carry "just in case". I'm adding a note I got from Mel Mallory of FS Ignitions just before I bought my Zipper distributor in 2008. The Pertronix module is extremely reliable and I have nearly 10 years and 15,000 miles on this ignition setup with absolutely NO PROBLEMS. How many times have you "points guys" adjusted your points and fiddled with your timing in that time period!!!!!!!!!!!!!!..............See Mels note below.
AL in NY |
04-05-2018, 11:04 AM | #12 |
Mel's Note...........
AL in NY |
04-05-2018, 11:38 AM | #13 |
Yes they look alike but I use the 1978-1981 model
04-05-2018, 11:43 AM | #14 |
The problem I see with coil is the way they are wired. The power comes off the starter and goes to the coil then the switch. I prefer going to the switch then to the coil.
04-05-2018, 12:11 PM | #15 | |
04-05-2018, 12:54 PM | #16 |
I have an original distributor and points in my '28 CC Pickup that I maybe drive 500 miles in a rare year. Most often less...sometimes, like last year, it won't make it out of storage.
In my Touring car, see avatar to the left, I have run the same Nu-Rex electronic ignition system for over 90,000 miles. I had an intermittent problem when I had about 10,000 miles on it and discovered it was a faulty ground. I tightened the ground and have had no road problems since. I do go through the wiring on my car every 3 years or so and clean all the connections so I assume this helps contribute to "no problems". I keep a spare module under the seat but it just collects dust. About 20,000 miles ago, I replaced the bushings in the distributor because I noticed they were sloppy but even with the worn bushings, it still ran without any issues. I have manual advance in this car. I am now building a '31 S/W Town Sedan as a touring car and will be using a FSI electronic distributor with the centrifugal advance. I will keep a spare module with me but don't expect to need it. I don't have a problem with stock systems but I prefer the electronic given my good luck with them. Good Day! Last edited by Dave in MN; 04-05-2018 at 01:00 PM. |
04-05-2018, 02:37 PM | #17 |
Briphaeton, I imagine you had to recurve the mechanical advance on that Honda dizzy as the Honda would run at much higher rpms, and probably the advance comes in later. But I love the idea of a vacuum advance. Vw parts are really just rehashed Ford parts anyway, right? Ha! Gotta try this idea.
04-05-2018, 02:52 PM | #18 |
No we didn't re curve the advance. I have a sheet a various Honda distributors spec. (somewhere) The VW distributor has a clockwise advance (good for the front drive adapter that Mr Yapp makes) and I seen Surburu electronic distributor used instead. I also read that Datsun distributor are a good replacement for Mallorys. The great thing about the Honda was they were only $25 then. I used to bring a might-vac and check it the vacuum held pressure.
04-05-2018, 02:56 PM | #19 |
I love points, There used to be a points option with the FS distributer. Thats what i have.
04-06-2018, 09:08 AM | #20 | |
If anyone has a wiring diagram of the Honda setup, please point me to it. Google has not been my friend on this, and seems to present everything from atvs to Cadillacs, but not the Honda wiring diagram. Maybe I'm too old for googling this one. Ha! |
