01-30-2018, 03:39 PM | #141 |
Re: Rare '40 convertible restoration project
Beautiful work, your a top shelf restorer. Thanks for the spare tire post. Frank PKNY
02-01-2018, 09:12 PM | #142 | |
I'm sorry I didn't address this sooner. Sometimes I seem to get scattered. On the frames and miscellaneous chassis parts I use Mason (brand) single stage gloss black enamel. It holds up very well and provides a deep gloss. I would not use this on a body panel... If I recall, it's about $300 or so per gallon.
02-01-2018, 09:12 PM | #143 |
Thanks Frank
02-13-2018, 08:28 PM | #144 |
Great news for me anyway... I'll get the back half of the body painted tomorrow. I'll probably do the front half Thursday.
I also managed to install the transmission / engine assembly to the chassis today.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 02-15-2018 at 10:28 AM. |
02-13-2018, 09:44 PM | #145 |
I don’t see the pictures......I know you wouldn’t post a “progress report” without pictures......right?????.......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
02-14-2018, 08:09 AM | #146 | |
I start painting in a few hours
02-14-2018, 10:42 AM | #147 |
delete
Thank God this is only a hobby! Last edited by funrunr; 02-14-2018 at 11:32 AM. |
02-16-2018, 05:02 PM | #148 |
Finally I've figured out the photo posting issue. Pretty good for a guy who is for the most part camera ignorant.
Anyway, the body is now painted. Monday I'll start wet sanding. That's a time consuming task as most of you realize. I'll go to at least 3500 grit prior to buffing. This project is finally coming together!
02-16-2018, 09:47 PM | #149 |
You have never mentioned that you have any help in your shop. Do you have any assistance? Bill
02-17-2018, 02:09 PM | #150 | |
Thus, when I need help, I am not fearful of asking
02-18-2018, 12:32 AM | #151 |
Mike looks excellent!! In regards to a mercury in a ford... is the transmission case a mercury case re-stamped with a ford number?
02-18-2018, 01:40 AM | #152 |
Mike, your process is unmatched and a pleasure to see.
02-18-2018, 08:24 AM | #153 |
Nope, it's a "regular ol' Ford" transmission.
03-12-2018, 07:13 PM | #154 |
Dropped the body down today. I am so happy
I hope to pull the jig out tomorrow and start assembling.
03-13-2018, 08:54 AM | #155 |
Mike - I'm getting dehydrated from drooling so much!!
03-13-2018, 08:31 PM | #156 |
I had a blast today! This is the fun part- when it finally starts going together. Now for certain there are not enough hours in the day! I don't want to stop...
Today was spent primarily on the inside of the body. I insulate any areas that will not be seen once the car is assembled. Although this car will most likely never be (road) driven, just in case it does - the insulation makes a huge difference in canceling road noise.
03-13-2018, 10:15 PM | #157 |
Heresy!
03-13-2018, 11:13 PM | #158 |
Mike, what color is this car? I can't tell if it is black, Lyon blue or maybe dark green. Maybe my monitor just doesn't show it well enough to tell.
I would say like the others, it meets your high expectations! |
03-14-2018, 07:36 AM | #159 |
I am far from anything that could be described as a photographer. It's Lyon Blue.
03-24-2018, 10:04 AM | #160 |
Still at it guys! Time, as you all know, is the rarest of commodities. Regardless, I'm making decent progress I suppose.
The doors should be painted very soon. I'll install them and do any final minor alignment that may be necessary and then start to install the top. In the meantime, I'll complete the dash, etc. installation. Most of the work "beneath the hood" is done.
