Old 07-12-2014, 05:12 PM   #1
mshmodela
mshmodela's Avatar
Default shock mounting hardware
Since my car has no shocks and ordered a set of Bill's shocks... looking for the list of mounting hardware.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-12-2014, 05:49 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: shock mounting hardware
You'll need arms and links. All probably available on such as Ebay, etc. The vendors also should have them.
Old 07-12-2014, 05:55 PM   #3
machine girl
is bill making shocks again?
machine girl is offline   Reply With Quote
Old 07-12-2014, 06:58 PM   #4
kingbee
kingbee's Avatar
Send a message via AIM to kingbee
Yes, a limited run. If you want them, get on his list.
Mshmodela. You also need special bolts and nuts, available from the vendors
kingbee is offline   Reply With Quote
Old 07-12-2014, 08:32 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
Brattons lists the special bolts, washers and nut set on page 109 .Part number24930 price $8.50 . This set bolts all four shocks to the frame. They also have the shock arms and links on page. 109 and 110 . I would recommend using new shock arms rather than used shock arms . If the balls are worn on the shock arms, the original style links will fall off and be lost. If the balls are worn on the front spring perches and rear axle housings , You will be safer using the later style dog bone links. The dog bone links was Fords better idea and was used from 32 through 48. These links used rubber balls that covered the metal link balls. If a dog bone link comes off on one end, the other end will still hold and the link won't be lost. With the original tube style link, if one end slips off of a worn ball, spring tension is lost and that is why the link falls off.
Old 07-12-2014, 08:41 PM   #6
mshmodela
mshmodela's Avatar
Thanks, and planned on all new arms etc... I naturally not aware of the benefits of the dog bone link...
-Mike
Cleveland, Ohio
Old 07-12-2014, 09:16 PM   #7
Purdy Swoft
Metal to metal contact wears quickly. Ford changed both the shock links and radius rod ball setup in 32 through 48. The rubber ball covers have to be replaced in time but rubber to metal doesn't wear the metal balls and was a better idea.
Old 07-13-2014, 02:29 PM   #8
C26Pinelake
Just so you know, Bill's shocks are $1100 for the shocks plus shipping.
Wayne
C26Pinelake is offline   Reply With Quote
Old 07-15-2014, 12:48 AM   #9
diomed
diomed's Avatar
I ordered a set of the shocks too. I'm looking at ordering the bolts from Roy Nacewicz
PDF catalog:
http://www.fordscript.com/ford_bolts...ogs/modelA.pdf
I'm hoping this is what we need:
R-84-13-A Special “D” shaped, fine thread shock absorber bolts, $ 12.95/pkg
nuts, locks in original S-2 finish. 1928-31 (12 pcs/pkg)
kris
diomed is offline   Reply With Quote
