02-18-2017, 07:59 PM | #1 |
Body mountimg
Does anyone have a picture of a 1928 Tudor sedan or if it's the same any car with the wood and pad installed in this part of the car? Or can someone tell me the sequence of which they go. If you can't upload pictur w you can email them to me [email protected]
02-18-2017, 08:38 PM | #2 |
Re: Body mountimg
I can't say for sure as I've only owned the one pickup... but it looks very similar to the 29 ccpu...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
02-18-2017, 09:06 PM | #3 |
Re: Body mountimg
1955cj5's photo is perfect. Rubber pad is under the steel, and the wood block is inserted into the hollow in the cowl. The cowl mounting has no rubber stapled to the wood block like all the other blocks. Getting that wood block into its position can need some persuasion.
02-18-2017, 09:09 PM | #4 |
Re: Body mountimg
Thank you 1955cj that's exactly what I needed
02-18-2017, 09:10 PM | #5 |
Re: Body mountimg
Thank you 1955cj that's exactly what I needed to see
02-18-2017, 09:12 PM | #6 |
Re: Body mountimg
Happy to be able to help...
02-19-2017, 05:16 PM | #7 |
Re: Body mountimg
Do I put felt under the rubber on top of the chassis?
02-19-2017, 09:08 PM | #8 |
Re: Body mountimg
The rubber sits on the splash shield, no felt or anything else.
02-19-2017, 09:21 PM | #9 |
Re: Body mountimg
I thought the splash shield had something under it... ( I could be wrong)...
What i thought was: frame rail, body welting, splash apron, rubber pad, then body with wood block slipped in. Also before slipping the wood block in is there anything you would coat the wood with to preserve/protect it? Did they used to use black creosote?
1929 Model AA - Need long splash aprons! |
02-19-2017, 09:46 PM | #10 |
Re: Body mountimg
What sequence do I use if I'm not running the splash pans?
02-19-2017, 10:28 PM | #11 | |
Re: Body mountimg
If you are building a rod with no aprons, I'd leave the welting off the frame. |
02-19-2017, 10:45 PM | #12 |
Re: Body mountimg
http://www.snydersantiqueauto.com/Co...ickup-8646.pdf
ahha I was right - its a pickup but same principles - notice the little info bubble in the upper right corner showing the order.
02-19-2017, 11:22 PM | #13 |
Re: Body mountimg
Awesome thanks guys
Thread Tools | |
Display Modes | |
