Old 02-16-2017, 01:44 PM   #1
cjkohnast
Default felt pedal pad
does the felt pad go between the boards and the plate or between the plate and the mat? Thanks
cjkohnast is offline   Reply With Quote
Old 02-16-2017, 02:10 PM   #2
100IH
Default Re: felt pedal pad
Under the metal plate, on top of the wood.
100IH is offline   Reply With Quote
Old 02-16-2017, 02:10 PM   #3
midgetracer
midgetracer's Avatar
between the boards and the plate.
midgetracer is offline   Reply With Quote
Old 02-16-2017, 04:53 PM   #4
Synchro909
Synchro909's Avatar
Felt pad??? Plate???? Am I driving a Model A? Does anybody have a picture to explain what this is about or even a diagram, maybe from a supplier's catalogue?
Maybe it is a LHD thing.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-16-2017, 05:03 PM   #5
Steve Wastler
Steve Wastler's Avatar
The floor board pedal plate ( lower left) and the felt pedal plate pad (top middle) photo ftom brattons
Steve Wastler is offline   Reply With Quote
Old 02-16-2017, 05:04 PM   #6
Mitch//pa
Old 02-16-2017, 06:37 PM   #7
Michael M
Michael M's Avatar
Could I have installed mine incorrectly, or have a defective felt? Seems like in only a few weeks the openings expanded and/or the pad shifted, causing it be virtually worthless for sealing out dirt and air.
Michael M is offline   Reply With Quote
Old 02-16-2017, 07:23 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Not the best design, is it?
Old 02-17-2017, 12:01 PM   #9
w.michael
w.michael's Avatar
My system works just fine. Felt pad, then metal plates, then rubber floor mat, then large bath towel wrapped around the steering column. Remove the towel in the summer because the air coming in around the steering column is cooler that the air coming in off the manifold/muffler on the passenger side.
W. Michael
w.michael is offline   Reply With Quote
Old 02-17-2017, 02:23 PM   #10
Y-Blockhead
W. Michael
I see my problem now, I forgot the bath towel...
Old 02-17-2017, 02:29 PM   #11
SeaSlugs
SeaSlugs's Avatar
surprised someone hasnt made a rubber flexable seal in place of the felt pad by now.
Would lightly oiling the felt let it slide on the pedals easier so its not getting pushed and pulled from friction as easily?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-17-2017, 02:45 PM   #12
duke36
have used double faced carpet or other tape to hold the pad to the metal covers
duke36 is offline   Reply With Quote
Old 02-17-2017, 03:27 PM   #13
goodoldvic
goodoldvic's Avatar
I stick the felt to the plates with weather-strip adhesive, if your pedal bushings are really worn the slop in the pedal probably wears it out quicker and makes the holes larger. That breeze through there is sumptin in the winter Rock on
goodoldvic is offline   Reply With Quote
Old 02-17-2017, 03:36 PM   #14
Synchro909
Synchro909's Avatar
Thanks Steve and Mitch,
We don't have such a plate on our RHD cars. The Model A club in South Australia makes a rubber one that fits reasonably well for our cars
Old 02-17-2017, 05:16 PM   #15
SteveB31
SteveB31's Avatar
We will be making a very nice rubber seal to go around the column in that location. they will available soon. He is making the mold next week.
Steve @ Berts
SteveB31 is offline   Reply With Quote
Old 02-17-2017, 06:24 PM   #16
Y-Blockhead
Steve @ Berts
Put me on the order list... They should be a great seller.
Old 02-17-2017, 07:39 PM   #17
Goldhardt
Goldhardt's Avatar
Glad to hear you're making one Steve, but I'm sure going to miss that little breeze in the winter!
Goldhardt is offline   Reply With Quote
Old 02-17-2017, 07:56 PM   #18
Art Newland
Art Newland's Avatar
Cool Re: felt pedal pad
Steve @ Berts
How about making something that fits on the pedal shafts, under the floor, that plugs the holes up when the pedals are in the up position?
Art Newland is offline   Reply With Quote
Old 02-18-2017, 12:34 AM   #19
Synchro909
Synchro909's Avatar
X 1,000 that. It is VERY uncomfortable driving a Model A in the summer with the heat from the exhaust coming up around the pedals. I've even considered clamping something to the pedal shafts that would seal against the under side of the toe board but there is soooo little clearance between the block and exhaust flange that they wouldn't work. (That's where the clutch pedal goes)
Old 02-19-2017, 12:01 PM   #20
Tom F OHIO
Tom F OHIO's Avatar
Synchro, I've never seen a RHD car. Are you sitting over the muffler? Or is everything just flip flopped to the opposite side. Is your motor different?
Tom F OHIO is offline   Reply With Quote
