02-19-2017, 11:56 AM | #81 |
Re: How To Lower The Model A The Old Fashion Way
Those are 1932 actuators and the arms go down.
Bob |
02-20-2017, 12:44 PM | #82 |
Thanks for the replies guys. Bob C is correct. These are 1932 actuators and the arm goes down. They are also 1932-34 king pins, which have the 'cup' offset differently than A and have the lock groove in a different orientation than the A parts. I have model A king pins and Model A actuators which fit and work as intended but the '32 actuators that I have are much nicer condition than the A actuators which is why I wanted to try and use the 1932 parts. I am going to give it another go maybe tonight. I left the king pin lock bolt out so that I could rotate the kingpin after I had the actuator installed in the cup.
Scott |
02-21-2017, 08:56 AM | #83 |
[QUOTE=Scott F.;1431939]Thanks for the replies guys. Bob C is correct. These are 1932 actuators and the arm goes down. They are also 1932-34 king pins, which have the 'cup' offset differently than A and have the lock groove in a different orientation than the A parts. I have model A king pins and Model A actuators which fit and work as intended but the '32 actuators that I have are much nicer condition than the A actuators which is why I wanted to try and use the 1932 parts. I am going to give it another go maybe tonight. I left the king pin lock bolt out so that I could rotate the kingpin after I had the actuator installed in the cup.
You are making this way too hard. Nice model a actuators are easy to come by and fit without the fuss. Well, maybe a little fuss, the bolt length on the model a actuator isn't long enuff to get a washer behind the nut, so you really need to grind a little off the sides of the perch pin boss. |
08-21-2017, 09:57 AM | #84 |
First of all, I want to thank LeroyM for this thread. It was instrumental in the dropping of my '29 Tudor.
I wanted to do a late 30's/early 40's style "banger build" with my '29 Tudor. The idea being that I would use what would have been available in that era and still maintain the mechanical brakes. Whether someone was doing dropped axles, back then, I have no idea. I have been unable to find any info on it if there was. So here's what I did... I was able to find and purchase a n.o.s. 1935 front axle, out of Minnesota. I found a nice pair of '32 front spindles as well as a new pair of '32 front spring perches. I then bought a new set of Model A king pins and spring shackles. I was able to find a trailer parts store in Missouri that sold the proper size spring bushings, 9/16 i.d. x 3/4" o.d. x 1 3/4" long. I reused my Model A brake actuators, backing plates and brakes. I had already installed a reverse eye main leaf and removed #2, #3 & #4 leaf's when I put on the 6:00x16's Firestone bia's ply tires but like LeroyM, I wanted it lower. So, there it is! I love the stance and it rides and handles great. Thanks again, LeroyM, for all the information. |
08-21-2017, 10:30 AM | #85 |
Location: South of Middlefart, north of Assens, Fyn, Denmark
Keep 'em kruzin! Dannerr |
08-21-2017, 11:01 AM | #86 |
08-21-2017, 11:29 AM | #87 |
Looks good. I like it.
08-21-2017, 06:38 PM | #88 |
08-21-2017, 06:40 PM | #89 |
08-21-2017, 06:41 PM | #90 |
08-19-2018, 02:41 PM | #91 |
I received my front axle. Now the gather the rest of the stuff to do this.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? Last edited by Chris Haynes; 08-19-2018 at 10:42 PM. |
08-20-2018, 09:45 AM | #92 |
Here's a before and after using the Old Yankee Speed Co "Hot Rod" spring and their main leaf reverse eye leaf on a stock front spring.
08-20-2018, 04:08 PM | #93 | |
I'm curious about caster? Some hot rodders and Model A owners are putting a 2" block under their bell housing to increase caster and this makes for very steady driving on motorways etc., However, if you lower the front of the car to improve its stance, then it will have the effect of reducing the caster, this in turn should affect the cars directional stability? Anybody had this experience? |
08-21-2018, 08:23 AM | #94 | |
09-02-2018, 03:36 PM | #95 | |
My chassis and suspension were set up by Macs Speed shop and he cut the radius arms near the axle and re-welded them giving 6-7 degrees caster. This certainly gives finger-light steering on motorways, but I think it makes it a bit heavier on tight corners. |
09-04-2018, 11:44 AM | #96 |
Just in the process of gathering parts as well to lower my 29 rpu. Thanks for the posters comments.
09-04-2018, 10:25 PM | #97 |
My '32-'36 axle and wishbone are at the powder coaters now. New spring Perches from Snyder's. I have the 1/4" thick fender washers to take up the slack between the axle and wishbone. Gonna have to buy an 11/16" drill bit to finish them. Next I will order my new spring from Posies Super Slider springs for front and rear. While waiting for the springs my backing plates will go to the powder coater. Spindles and brake drums will get a bath in Parkerizing juice. Its getting close.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
09-05-2018, 01:19 AM | #98 |
Have Snyders begun selling '32 perches?
Can you take pictures, as you start on this?
09-05-2018, 11:19 AM | #99 |
09-06-2018, 01:40 PM | #100 |
I am using "A" perches.
