02-19-2017, 12:12 PM | #1 |
28-29 Step plate
Hi Guys:
I've gone through the Judging standards and the books I have and can't find out if the original car had a "gasket" between the rumble seat step plate and the fender. I have a rubber gasket but I think it was just an addition to keep the paint from chipping. Is it like the door handles and there's just a black paper gasket not a rubber gasket? Look forward to your input. John Poole |
02-19-2017, 01:28 PM | #2 |
Re: 28-29 Step plate
I believe I read somewhere, I can't remember where, that Ford did use a gasket between the step plate and the fender. I think it is a good idea to use a gasket, probably a rubber one, since that is all that seem to be available, to eliminate the chance the paint would chip. A lot of weight could be put on the plate with a person getting into and out of the rumble seat. The picture below is of a fine point 29 roadster that was at the 2016 MARC meet. Note that it has a gasket under the step plate.
Rusty Nelson |
02-19-2017, 01:45 PM | #3 |
I think this is it A-41568 Pad(deck step) on rear fender.
Bob |
02-19-2017, 04:00 PM | #4 |
My 29 Coupe has a square step plate on the fender. Did some come through with a round step plate? John
02-19-2017, 04:38 PM | #5 |
The step plate on the fender did have a pad between the step plate and the fender. It was a hard fiberboar,d very dark brown or black. It was flat and did not have a lip on it.
02-19-2017, 04:44 PM | #6 |
Bob |
02-19-2017, 05:32 PM | #7 |
lindy williams, post #5 has given the correct answer :
-"The step plate on the fender did have a pad between the step plate and the fender. It was a hard fiberboar,d very dark brown or black. It was flat and did not have a lip on it." Or at least that is what all of my five originals have, and all the originals I have seen and collected over the last 50 years. |
02-19-2017, 08:39 PM | #8 |
These ARE covered extensively in the Judging Standards, Area 15 - Exterior Plating. The information you are seeking is on pages 15 - 14 and 15 - 15.
It states there were four styles of step plate pads, and then goes into detail on each. Stew
Always one bad decision away from a good time. |
02-20-2017, 08:42 AM | #9 |
Thanks Guys for the info. I'll read the judging standards again. I'm trying to make it right.
John |
02-20-2017, 09:16 AM | #10 |
Well I've checked the Judging standards and mine edition only goes up to pg. 15-10. So there must be a newer revision then I have. Thanks again. JP
02-20-2017, 12:03 PM | #11 |
Hey, John. Rev 4-2016 covers the different types of rubber step pad gaskets. If you need the info, give me a call.
Glenn
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
