Old 03-16-2024, 02:52 PM   #1
deuce lover
deuce lover's Avatar
Default One Fast Flathead
Click on the video and enjoy
https://www.jalopyjournal.com/?p=57839
Old 03-16-2024, 03:16 PM   #2
rjlester
Default Re: One Fast Flathead
That was beautiful. The thumbs up at the end spoke a thousand words.
rjlester is offline   Reply With Quote
Old 03-16-2024, 04:30 PM   #3
34fordy
34fordy's Avatar
LOVED IT !!!!!!!! Goose bumps galore! Wonder about RPMs?
34fordy is offline   Reply With Quote
Old 03-16-2024, 06:25 PM   #4
Lawrie
Lawrie's Avatar
Look on YouTube,under blown flathead dragster at benaraby.
Lawrie
Old 03-17-2024, 08:18 AM   #5
pistonbroke
I raced door slammers at SIR and Bremerton Washington for many years and this made me feel like I was right back in the day. Thanks ,Tim
Old 03-17-2024, 09:58 AM   #6
Planojc
Planojc's Avatar
Would love to see a close up of that engine.
Planojc is offline   Reply With Quote
Old 03-17-2024, 01:43 PM   #7
Randy in ca
Randy in ca's Avatar
Picture:
Randy in ca is offline   Reply With Quote
Old 03-17-2024, 05:03 PM   #8
Ronnieroadster
Ronnieroadster's Avatar
Rick Schnell's Blown flathead burning nitro methane fuel on an engine dyno is capable of making 900 Horsepower. RPM is 7000 at the 1320 1/4 mile mark. Block is filled with aluminum then the intake and exhaust ports are modified. The heads start as a solid block of aluminum then Rick machines the combustion chambers to work in the extreme environment burning nitro. Many years of development went into the Sliders engine to produce the power needed to run near 180 MPH in the quarter mile.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-17-2024, 06:19 PM   #9
cmbrucew
cmbrucew's Avatar
Ronnie How many runs can that engine make?
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-17-2024, 08:41 PM   #10
Ronnieroadster
The only time I saw the car it made two runs that day. There's never really been any other competition to run against Ricks car so going rounds at an event wasn't done to my knowledge. Exhibition runs were more what the do when the car runs.
On occasion when Rick was pushing the envelope if he experienced a lean out that always would cause a damaged piston and cylinder which at times meant another block would be needed. That would not be an easy job replacing the block considering the amount of work it takes to modify the blocks.
Ronnieroadster
Old 03-17-2024, 09:45 PM   #11
Pete
Pete's Avatar
And after all that he is still leaving a LOT of power on the table.
If he were to pursue it, who would he race? He is in no man's land. Too fast for vintage and too slow for NHRA.
Old 03-18-2024, 03:44 PM   #12
Henry Floored
Henry Floored's Avatar
What did Flathead Jack’s twin engine Flathead dragster run? I’ve never seen any times for it. It was a beautifully turned out piece. Does it still exist I wonder?
https://youtu.be/y9q6AS-11fs?si=cgYMK6YNYtk7Tteg
Henry Floored is offline   Reply With Quote
Old 03-18-2024, 03:56 PM   #13
Tim Ayers
Curious about your opening sentence. What more do you think could be done to make it go faster, Pete?
Tim Ayers is online now   Reply With Quote
Old 03-18-2024, 04:05 PM   #14
Pete
Pete's Avatar
The next size up blower would help greatly.
Dry sump.
Bigger fuel.
Ports like Ron Main did.
And several other things I won't mention.
Old 03-18-2024, 05:02 PM   #15
Tim Ayers
Dry sump.
Bigger fuel.
Thanks for expanded. What does bigger fuel mean? Like a richer ratio/mix of nitro or a 100% load?
Old 03-18-2024, 06:06 PM   #16
Pete
Pete's Avatar
100% is not as far as you can go.
Past that is the most fun you can have with your clothes on.
Old 03-18-2024, 06:13 PM   #17
Tim Ayers
Ahhh. Gotcha
Old 03-18-2024, 06:54 PM   #18
Ronnieroadster
With those ideas the poor block wont take it for very long
Old 03-18-2024, 06:57 PM   #19
Pete
Pete's Avatar
You would be surprised.
Old 03-18-2024, 07:00 PM   #20
Pete
Pete's Avatar
Oh, I forgot to mention the next "up" blower would be a centrifugal.
More out for less in.
