Old 09-02-2014, 07:13 PM   #1
david801
david801's Avatar
Default Carb fuel inlet thread
I am rebuilding a Zenith carb using the Tom Endy guide and I want to set the float level. I can't find a brass fitting at the local auto parts store or Home Depot that has the 1/2" 20 thread so I can make a test jig. All the brass fittings have a pipe size measurement which is very different than the bolt size mentioned above. I can order the fittings in a Model A catalog but I don't want to wait a week. Any suggestions where to get the correct fittings for the test jig? Is there a pipe size to bolt size cross reference?
david801 is offline   Reply With Quote
Old 09-02-2014, 07:28 PM   #2
KMeredith87
KMeredith87's Avatar
Default Re: Carb fuel inlet thread
I just bought some the other day to hook up a Model B carb...cannot remember off hand what the thread ended up being however, did you ask to go behind the counter to there bins of fittings? I can almost never find what I need out on the shelf up a lot of places still had a semi decent selection behind the counter you just have to ask. Make sure you take your carb or upper housing with you. I got my fittings from O'Rielys
After some research it looks like it is 1/2 20 pipe thread
KMeredith87 is offline   Reply With Quote
Old 09-02-2014, 09:03 PM   #3
Tom Endy
Tom Endy's Avatar
Try an Ace hardware store. Take along a carburetor or a fuel line to compare. You want a fitting that uses a furrel.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 09-03-2014, 10:50 AM   #4
TDO
TDO's Avatar
Ace Hardware will have those fittings.
TDO is offline   Reply With Quote
